Power mode?
Im under the impression that all power really does is raise the shift points a few hundred rpms. It should not hurt your car, only gas mileage. In theory, over time running at slightly higher rpms might cause more engine problems but i do not think it would be signifigant at all.
Upshifts later and downshifts sooner, for a given throttle position. Speed of shifts is same, either way.
No harm...........except that, in theory, the motor wears out a little sooner (rings at 295k miles instead of 300k......boohoo).
Mine stays in power mode, but I gateshift most of the time and usually run even higher revs than the ECTi would shift me at.......
DD
hey - about the gate shifting, i was wondering, how much is too much, how much are we allowed to play around with it?
ok, ok, i know driving it around all the time at redline is not a good thing. but that gated shifter gives us access to all 5 gears, that seems like an invitation to play!
so how often do u guys hold the gears down low to let it revv up?
I don't gate-shift but I leave my car in Power mode all the time and my car doesn't move forward without me using the E-Shift. And I'm ALWAYS at high RPM's always......
you89
07-07-06 09:29 PM
