Megan Drift Spec True Dual - too raspy
Old 05-01-12, 09:42 AM
DaXxJaPxX
DaXxJaPxX's Avatar
Default Megan Drift Spec True Dual - too raspy
So about a year ago, i ordered the megan drift spec axle back exhaust, and had my local exhaust shop chop it up to try a true dual set up. I also had them remove the resonator as well. It sounds great below 3500 rpms, but gets extremely raspy above 3500, and sounds horrible. I'm just wondering how to fix this? Would an x-pipe help smooth out the tone, or maybe toss resonators back in? Thanks in advance
-JaP
Old 05-01-12, 04:07 PM
A_Grasso
A_Grasso's Avatar
Put your resonator back on or get a mid pipe
Old 05-07-12, 10:24 AM
DaXxJaPxX
DaXxJaPxX's Avatar
hmm, guess i'll post in the classifieds and try to get 2 resonators.
Any thoughts on adding an xpipe to the exhaust?
Old 05-07-12, 11:15 AM
dorkacho
dorkacho's Avatar
if you don't mind me asking, what's a "true dual" setup?
Old 05-07-12, 11:20 AM
06isDriver
06isDriver's Avatar
that center resonator is THE only thing that cuts the rasp out. You'll definitely need to get two bullet style resonators
Old 05-07-12, 03:54 PM
DaXxJaPxX
DaXxJaPxX's Avatar
yea, thats what I keep hearing. I also thought x-pipes also created a smoother tone, cutting out the rasp. i just don't want to spend the $ on getting the resonators installed and still have a bit of rasp, which is why im debating throwing on an x-pipe as well,which i'll most likely do
Old 05-08-12, 08:00 AM
06isDriver
06isDriver's Avatar
probably wouldnt hurt. I mean, we're talking about a negligble amount of loss/gain.
Old 05-08-12, 01:54 PM
KillaIS250
KillaIS250's Avatar
Each outlet has its own piping basically. On the stock exhaust, it's just one pipe that splits into two using a Y-pipe...
Here's the stock IS exhaust..
http://a3.sphotos.ak.fbcdn.net/hphot..._7935023_n.jpg
Here's a true dual exhaust..
http://www.enjukuracing.com/product_...73626_zoom.jpg
You can see how the stock exhaust flows into a single pipe and then back out into a dual using that Y pipe at the end to split it. But if you look at the true dual exhaust, you can see it has 2 separate pipes all the way down and doesn't join into a single pipe...hence the term "True Dual"
Old 05-08-12, 02:26 PM
dorkacho
dorkacho's Avatar
ah i see, thanks!
but what do you benefit from such true dual setup?
Old 05-08-12, 02:39 PM
KillaIS250
KillaIS250's Avatar
True dual will allow for more exhaust gas to escape quicker so you get better performance and makes for a better sounding exhaust. The disadvantage is the extra piping can add weight and slightly (better yet - negligibly) reduces the torque at the lower end of the RPMs.
OP - IMO, an X-pipe (or h pipe) is a must for a true dual system if you want it to flow correctly.
Old 05-08-12, 03:01 PM
dorkacho
dorkacho's Avatar
thanks !
Old 07-03-12, 07:21 AM
DaXxJaPxX
DaXxJaPxX's Avatar
slight update even though i havent been on here in a month. Cars in the shop, apparently my secondary cats are clogged up, so those are getting removed. I'll be replacing them with an x pipe and 2 resonators, hopefully my car purrs now instead of sounding like a 99 civic =/
Tro209
10-08-16 07:57 AM
aly250
Performance
03-19-11 07:45 AM
LBC_IS300
IS - 1st Gen (2001-2005)
02-01-10 12:21 AM
CodyLexus
03-23-07 01:03 PM
2001slvrIS
Performance
04-04-05 10:09 PM
Quick Reply: Megan Drift Spec True Dual - too raspy
