r154?
The tailshaft is different because they use different motor mounts.I used IS300 trans mount and it bolts right ON.
Like the other have said , it's not cheap so just make sure you know what you are getting yourself into.
You need a Driveshaft, clutch, bellhousing, shifter extension , throw out bearing with shims and clamp, clutch line, master cylinder , slave cylinder, 1jzgte flywheel, trans mount, MC speed sensor converter, flywheel bolts, pressure plate bolts.
Gl
Gl
gentlemen... thanks for the responses. looks like i need to send my Evo trans to get built... so this project most likely wont happy this year.
oh well. you gotta pay... to play!
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Irslopra
Performance & Maintenance
08-17-10 07:14 PM
