help AEM conversion harness for 2jzgte vvti swap
please help i am swapping a 2jzgte vvti in my sc300 and want to run AEM standalone but i need the conversion harness to run AEM anybody know where i can pick one up??? help help thx
Good luck man... you are better off building the stock motor and turboing it, trust me, I've done both recently...
You are in for a wiring lesson, for sure...
First off, what year SC? Then, which AEM? Which wiring harness? Planning on using a universal AEM or a Supra AEM? Not so sure if what you are looking for exists. Most people that swap in a 2jzgte are using an Aristo and swap in its wiring harness as well, as your stock harness won't have all the correct connections for that motor... Once that swap is done, it will plug straight into an AEM for the Supra, but may still require some repinning of certain ECU inputs...
