02 GS300 + 50 Shot Nitrous .. What do I need?
I recently got an 02 GS300. Im happy with the car, but would very much enjoy and more "umph" especially since I came from a single turbo MKIV supra...
I dont want to waste my time with super chargers or turbos, but I was condiering a wet nitrous system...
besides the system, what options should I look into before I attempt this project...
such as:
fuel enrichment
which nitrous kit
etc etc ..
I was planning on running 1 jet into the intake, that way I wouldnt be modifying the mainfold and would make it very easy to switch back to OEM...
Comments suggestions, pictures would help out alot!
Thanks!
such as:
fuel enrichment
which nitrous kit
etc etc ..
Thanks!
NOS is the least $ for the HP. However be prepared to fix parts if you run it too much or don't want to spend 5 hrs on the dyno to check which cylinders are rich and lean and play with the set up. Do it right.
I went from NOS only to adding a SC because I wanted the power most of the time and with proper tuning the blower is a safer route on the engine.
NOS will add exhaust temp through the roof and MAY reck OBDII O2 sensors, valve seats...
I am a firm believer in NOS and ran 175 shot untill the SC which is now a 90 shot of NOS direct port. (DP is the only way to go).$$ safer too.
MY 2cents you will get sick of the nos and want it all the time. save your $$$ and get the turbo it will only add value to the car while NOS will devalue the car.
Good Luck!
Good Luck!
yes I agree and also knew what you were saying... I was hoping to get some application info from someone who actually has it in there car...
btw, who has SC kits for ghte GS300... and whats the entry level one?
Forum Administrator
roenick7 IS the only person I know on CL who "actually has" nitrous on a GS. His is a GS400, not a 300 however.
Click here for a link that has a picture of his setup -->LINK
Might want to use the search feature to look for NOS or nitrous.
