Finished: Custom AEM EMS V2 Install IS300 - plug n play what?
I have thought about installing my emanate ultimate, only to skew the MAF signal, to fool the factory ecu... I have also thought about a way to do this with the AEM... last but not least, have really put some thought into an aftermarket level and gauge and who cares if it moved around alot...
So I have something further to add to this..
I have just converted my throttle body to a SupraTT cable throttle..... and guess what.... I now get the exact same weird fuel readings as you mitsuguy. Keep in mind up until this point my gauge was still reading linearly and correctly.
So that certainly tells us something interesting... now that my DBW system is in fault (I have several codes related to this) it totally throws off my gas gauge readings. I am still using the exact same TPS sensor, just that now the peddle position sensor and DBW motor are not plugged in.
Whats also interesting is that the system is very much linked to the MPG gauge as you mentioned... As the ECU does not seem to detect the faults right away it takes a minute or so of driving during which time my MPG gauge still works and fuel level actually drops as it normally would. After that my TRAC light starts blinking and the MPG gauge just sits at the top while driving around and at the bottom while stopped.
I just tried taking apart the old DBW throttle body and removed the motor and pedal accel sensor to try just having them plugged in to see if the ECU would be happy enough with that - but no luck it still faults out.
I've got another idea which may work, which I'll try when I get more time...
just a heads up, on 23 psi and a Mustang Dyno, this car now makes 500 whp / 476 wtq, on 26 psi, using Virtual Dyno and Dynojet settings, it makes 630 whp, about 540 if it was on the Mustang Dyno...
it is a whole lot of fun!
So I have the 30-6050 Honda box from drift motion. My engine ran when it was hooked up to a 1jz. Now I have a 2jzgte vvti. And it won't run. It doesnt see cam signal.
I did manage to see those super small resistors were still on the board for R2 and R4. So if I have those removed, the aem will see cam signal better?
The map for VVTI cam/crank sensor setup is not correct in the setup wizard... email me mitsuguy@gmail.com and I can get you the right cal file to get stat sync...
Are you running it in conjunction with another ECU?
Hey guys, digging this thread up a little but i'm getting desperate on my driftmotion 6050 aem box, ran fine on my 1jz but now i have a 2jz gte vvti like Doomlight. Seems there is so much information about making this work scattered around the internet, but piecing it all together is a challenge. Doomlight did you end up having to remove those resistors to get it to run?
I can send you a calibration file if you need one that works with VVTI cam and crank sensors.
