Finished: Custom AEM EMS V2 Install IS300 - plug n play what?
#31
That would be a huge help thanks Mitsuguy. I was going to wire the aem in conjunction with my factory ecu, perhaps i'd be better off running it as a full standalone. What seems to be the easier swap in your opinion? There are so many posts surrounding this swap but none that are black and white, some say remove resistor R2 and R4, others say R14 and R16 etc. Giving me a headache.
#32
Does the wiring also work on an Aristo ECU.. Obviously the pin outs arent the same, but every pin should be more or less there if they are in the IS300 ECU.
Does a 6050 box need to do some internal resistor mods?
#35
Hey mitsuguy, Very helpful and detailed write up. I am looking to swap a 1JZ-GTE into my 2002 IS300.
Got a question about this your setup in regards to ODB-II emissions. Does your setup trow any CEL codes? I live in an area that requires ODB-II emission. Thanks.
#40
2nd: i wanna keep my auto, what all do i need to wire in with the ecu to keep autmatic?
