Testing: Cold Air Intake design, not a short ram hot air or enclosed filter setup
#32
Is that your setup? Post details and pics! Have you done anything to cool IATs after heatsoak? This is my main priority of concern and next objective to tackle. Got another Meth/Water setup ready to install and looking at Cry02.
#33
I took apart the actual intake mainfold and covered the bottom with the gold looking heat shield film. ( I forgot the name of the company) but it has a sticky back so you can bascially put it on anything. I also covered the bottom part of the intake tube. That really helps, ive noticed the intake tube does not get super hot anymore. I also plan on getting the headers coated with a heat wrap. They claim to lower the temp in the egine bay and make power.
#35
Had some time to do a 3.25" inner diameter mock up CAI. I'm pleased with how it's going to turn out!! Super straight and beefy as hell, it looks mean in person! Just have to get the injector nozzle bung, hose and MAF flanges welded up. Check it out so far:
![](https://imageshack.us/a/img402/2764/imagejlj.jpg)
![](https://imageshack.us/a/img266/5148/imageuha.jpg)
![](https://imageshack.us/a/img19/1411/imagemxaj.jpg)
![](https://imageshack.us/a/img99/3858/imagepzp.jpg)
![](https://imageshack.us/a/img441/5751/imagegjh.jpg)
#36
Nice Mike! I like the look and the idea. Let us know if you have any improvement from the 3.25" piping.
You have a pipe bender in your garage? If so, that's sick! We don't even have that at work (in our machine shop). If we did, I'd be bending everything!
You should consider offering this for sale....
#37
Nice welds on the 6061 aluminum piping, just need to polish and get a finished look....that will be way later.
So, this is looking really promising with a few tweaks remaining. I shortened the overall length a few inches from the previous 3" setup I was running. As a result I want to kick the end of the piping in the fender out about 10 more degrees to give the air filter a bit more breathing room. Additionally, I want a straighter flange alignment with the piping where it meets the throttle body. I have a "hump" hose on its way as I dont want to add another 1" of piping or try and bend that close to the TB entrance.
The car drives fanf*c%ingtastic in my opinion! I truly dont have a biased opinion coming from the S/C setup but this car actually still feels quick with just a huge intake. Call me crazy but I'm more then pleased with my findings and how the car responds and feels. I'm going to have to dyno but no firm plans just yet.
ES808- I only have a 16ton pipe bender. Its nothing fancy and very tedious but gets the job done. I bought it from a local exhaust shop that closed its doors years ago. It bends aluminum just like a mandrel bender....Steel it crimps like a crushed bend so I dont use it much for anything too heavy duty.![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
I'd consider a go to market with a real "CAI" but the bill of materials is adding up quickly. I'm not sure how worth it to anyone this would be esp. having to cut sheet metal to utilize the setup.
![](https://imageshack.us/a/img687/6672/img1708rw.jpg)
![](https://imageshack.us/a/img855/7514/img1710lv.jpg)
![](https://imageshack.us/a/img542/1726/img1709vq.jpg)
![](https://imageshack.us/a/img171/2091/img1712wm.jpg)
![](https://imageshack.us/a/img689/3117/img1714wx.jpg)
![](https://imageshack.us/a/img255/2032/img1716ai.jpg)
![](https://imageshack.us/a/img41/7017/img1711nb.jpg)
#44
Mike,
That 16 ton bender does a great job with the aluminum tubing. It looks just like a mandrel bender did it. And the welds look good too.
Let us know how the GForce module works too. I'm curious to find out if it works. But like you, I have my doubts as well. $65 for extra hp/gas mileage? I highly doubt it.
#45
The only things I would be concerned about would be if intake temps are worse than with the stock setup. I know you said you felt the pipe after driving, but this is most likely because the intake air is cooling the pipe as it travels to the throttle body. That is a long stretch of pipe over the engine, and it is surely picking up some heat. I'd be interested in a IAT comparison between this and the stock setup. Also, I'd look into trying a version that is ceramic coated or JetHot coated. That would go a long way to thermally insulate it.
Additionally I'd be concerned about water ingestion like others have mentioned. Might be worth its weight in gold to develop a splash guard for the filter element.
