what's the difference between intakes?
I've noticed most intakes cost around $200+ I assume the intake piping is all the same, and it's the filter that matters. so why not just get a cheap eBay intake, and buy a K&N filter for it? Am i missing something??
http://www.ebay.com/itm/Air-Intake-S...c9071b&vxp=mtr
http://www.ebay.com/itm/2006-2008-Le...34d69c&vxp=mtr
The piping is what improves the HP, not the filter. Most of the options out there don't even increase HP (such as the one you linked) because the heat soak that occurs from not taking in fresh, cooler air from outside the engine compartment. Utilizing the stock air box with a smooth walled pipe is what improves the performance (Joe Z or F-Sport intake). If you're looking for more noise, the option you linked will do just fine. In either case, any improvement won't be noticeable.
A Joe Z intake is $125 and replaces only the intake pipe and makes as much or more power, sucking colder air, than all the expensive short rams with giant unneeded cone filters do.
(though the short rams do make more noise if you're into that)
F-sport= Joe Z clone, but makes more noise thanks to lower airbox piece, comes with a reusable filter (which is a $ saver if you plan to keep car over 60k miles), and is the only intake legal in California... but costs 3x the Joe Z.
All the short rams= significantly louder than either of the above, price usually in between (or nearer the F-sport), power add is questionable since you'll suck hotter air.
JasonChang
Performance
12
05-30-12 10:07 AM
92Es300 5sPd
02-18-03 03:35 PM
