My auction site intake experience.
Old 09-12-12, 08:04 PM
supralative
supralative's Avatar
Default My auction site intake experience.
Ordered an intake from ebay to see if its worth it to save some off of the more well known names in the industry. I have accounts with vendor such as AEM, GReddy, HKS, APEXi, K&N, etc....wanted to give this kit a shot.
Well package arrived very well packed and no damage at all. Instructions were supplied as well that showed what was needed to be done pretty clearly.
Overall fitment of the intake kit is real good...I would say 95%. One bolt on the base was kind of tight but it was a real easy fix. Only other small issue was the coupler supplied is abit too large for the 3in intake pipe itself. I ended up using a old GReddy 3in coupler I cut down to use as a sleeve inside the supplied coupler with kit and no problem. I think the ideal size is probably 3in to 2.75in for the coupler used the throttle body connection. This kit supplies a nice powdercoated black barrier that if you took time to put some heat backing material on it would serve very well. The kit supplies with two rubber molding pieces to act as a seal somewhat underneath the hood. I plan on going back in later and adding the heat barrier to serve its purpose. Only change I will make is getting a better quality filter such as a K&N that I trust more.
Hopefully I will see some increase in MPG's with this, but the sound does sound good at WOT.
Going on next will be the M2 exhaust.
Old 09-12-12, 11:41 PM
sm1ke
sm1ke's Avatar
Who's the ebay seller and how much did you pay? I had an issue with an ebay intake I bought for my Accord. One of the braces that bolts to the engine bay broke off and took part of the pipe with it. That was after 2 years of use though.
Old 09-13-12, 05:07 AM
bob4256
bob4256's Avatar
I doubt you will be getting any increases in MPG since its a short ram
Old 09-13-12, 09:05 AM
supralative
cmpautoparts11
$100
we will see
stock on the highway home was hovering right around 30MPGs
in city so far any where from 25-28 depending on how i drive the car
a mile or two is helpful in any way for sure
Old 09-13-12, 09:36 AM
bob4256
bob4256's Avatar
Originally Posted by supralative
cmpautoparts11
$100
we will see
Well the thing is that short rams suck in hotter air than the stock air intake does so you may be getting less MPG than you did before.
bob4256
bob4256's Avatar
There arent any cold air intakes out there for our cars so no intake will for sure give you MPG gains.
Old 09-13-12, 09:53 AM
supralative
i will post up those results for you if it goes that way as well
Old 10-17-12, 06:11 PM
ChaseRaz
ChaseRaz's Avatar
Were you able to but the plastic engine covers back on?
Old 10-18-12, 07:39 AM
supralative
Yes the covers fit on with no issue.
Center one is some snug but you can position the pipe for abit better fit underneath.
Old 10-18-12, 10:04 AM
sm1ke
sm1ke's Avatar
So what's the word on the mileage? Any losses or gains? Did it stay the same?
Old 10-20-12, 07:35 AM
supralative
I gained like about 1-2MPG's.
Not huge but any bit helps.
This was using cruise to keep this somewhat similiar.
Old 10-22-12, 03:39 PM
MastroIS
MastroIS's Avatar
I feel intakes are all the same. As long as the fitment is proper, and the filter element is good, it makes little to no difference.
Old 12-03-12, 05:55 PM
LexusIS954
LexusIS954's Avatar
i payed 38$ for mine. Since the gains are minimal for any intake i dont see the point of spending alot of money. it sounds good and adds a little shine under the hood for less than 40 bones
Old 12-04-12, 06:27 PM
Slammer1
Slammer1's Avatar
I scored a used K&N (just one scratch on the tube) for $68 a little over a year ago. There are deals online, you just have to know what you want and be patient. The K&N retails for around $320....
IMCHIA
02-08-18 10:25 AM
Ne1tHeRe
1Gen RC350 / RC-F Classifieds
05-30-17 08:33 AM
felen310
Performance
12
08-29-15 08:23 PM
Quick Reply: My auction site intake experience.
