solution to jdm twins overboosting with 3" exhaust
Old 04-08-13, 07:56 PM
Evlc36
Evlc36's Avatar
Originally Posted by Meyagi
stock boost is 12-14psi i think, so at 18psi you are overboosting. with my boost controller turned all the way down i can hold 11psi which is wastegate pressure all the way to redline. i didnt want any boost spikes and blown apart ceramic turbos.
17-18PSI is well known to be the upper end of acceptable boost level for the JDM ceramic twins without significantly shortening their life (unless you are really unlucky)
That is the pressure I have chosen with my boost controller - with boost controller turned off it ran around 14psi I think.
Stock boost is around 11-12psi from memory.
I have been running 15psi on first turbo (below 4000rpm - using 2nd boost controller tweak) and 18psi on both turbos above 4000rpm (still running sequantial setup) for about 12,000 miles and everything is running fine.
I have 95,000 miles on the odometer btw.
I too will be pulling off the twins soon and replacing with a Garrett GTX35R.
Old 04-08-13, 08:21 PM
vbieds
vbieds's Avatar
Well, you too should do a diy. Single is way way way way way in the near far future for me.
rickytsui
Performance & Maintenance
11-03-12 10:02 AM
sj408
10-07-09 12:23 AM
shaodome
17
05-16-09 09:21 AM
chitwnsazn
29
03-21-05 12:32 PM
Rob_O
01-25-02 08:25 AM
Quick Reply: solution to jdm twins overboosting with 3" exhaust
