usdm 2jzge vs jdm 2jzge
I have done a bit of research on the us and jdm 2j's and just needed you guys input. here is my situation my old us 2j practically is about to give bearings going bad and other things. I have found a complete motor, ecu, ignitor chip, and uncut harness on the jdm 2j for about 1k shipped to my door. Now I plan on running a complete jdm swap because we do not have emissions in KY and was wondering if I would have to change any sensors out which i do know i won't be running maf on it as well if that is possible. I am new to the Lex family and just need some input on what the do's and don'ts are thanks.
why not just swap out the bad parts on your existing motor instead of gambling on an unknown JDM motor that you will have to do work on regardless to make it work?
Work smarter not harder
well due to the fact being is that my oil pump is going bad and also my bearings as well I plan on rebuilding the motor to have spare laying around. And i needed it fast because i can't ride my r6 during fall and winter and also i have a child and looking for a reliable motor to get me going. did not want to invest to much money as it is right now just trying to get the damn thing running and going. i just need some inputs on if i can do the swap without swapping any parts over to run usdm. but if their is chance i have too, it wouldn't matter either way it goes. I just need to know if i would be running into any snags like some parts are not interchangeable egr i know it does not have it on the jdm swap and also maf sensor anything else i should also need to know
so whats the difference if i gamble on an unknown jdm motor everybody else does it when the go with an aristo 2j its a gamble no matter how you look at it.
It's a gamble and I lost. Mine had lowish compression in a cylinder and I'm rebuilding it prior to putting it in. Unfortunately not there yet else I'd sell you my original motor.
where did you get your motor from? i know the feeling man i will probably rebuild my old motor completely so i will have an extra spare motor just in case this one fails but will see what happens in the next couple of days. hopefully the jdm swap will go smoothly but we all know nothing goes smoothly.
I personally wouldn't swap like for like...if you are going to swap, make it worth your while.
well i have already have brand new parts like timing belt, water pump, tensioner, idler pulley, and serpentine belt tensioner and will be replacing the thermostat as well. i made sure i will be replacing the major components outside the motor, but if you think i should stick with the usdm parts like maf, and throttle body i have no problem doing that any good inputs will be taken in consideration it will arrive sometime later today.
