Just recieved PPE Headers for 01 GS430 - Unboxing.
#31
We normally use an infrared temperature gun, thermocouples are a pain cause you have to weld in a bung. I don't have the numbers anymore, but it is noticable enough to feel with your hand when it is on the dyno.
We had similar results on our Lotus Elise/Exige headers where the outlet was too small and causes it to heat up a lot at the collector. The ceramic coatings we have also make a big difference in temperature reduction. They are inside and out which offers twice as much insulation and protection.
#32
The factory manifolds have a major restriction around the outlet, it is a log style manifold. The restriction in the manifold causes them to get very hot. Our design is much larger at this point and runs much cooler. The headers are also ceramic coated which is a very effective thermal barrier. Removing the heatshield around the shaft will not cause any problems.
We have prototyped and tested all of our designs on cars here at our shop. We have had more than one GS430 come in to prototype and test fit over the 2 years that we have been making these, as well as SC430s (same header). We have customers here running for 2 years with the heatshields removed with no issues.
Alsoo i noticed you guys might have ti change the exhaust gaskets too.
#34
put them in, noticed it was rubbing the heat shield.
ended up cutting the heatsheild, alot alot more play and steering is awesome! (no more rubbing!!)
car def has more pull. no solid numbers or anything yet. but i did notice my mpg get worse.,..
so before the header install i got 11.3 which in my point of view is pretty bad.
after i installed the headers i got 9.2 mpg.....
on top of that i did a tune up also, new plugs new oil this that and what not.. anyone know why im running only 9.2mpg
![EEK!](https://www.clublexus.com/forums/images/smilies/eek1.gif)
#37
welcome....for some reason my flange on the passenger side doesnt fit correctly where the car bolts to the header. i should have installed the flex couplings i bought from him but i didnt and i have been trying to fix this exhaust leak without rewelding the flanges. my issue i dont think is with the header but with the fact that i have been scrapping the exhaust thus pulling on the flange joints and stretching out so to say
#39
^^ sorry for being a noob but which exhaust tube is bank 2?
I just opened the correct headers (I think they are, don't really know how to confirm) and the welds seem to be worse than the original set I got =/ much thicker and sloppier. I'm also still missing the 10mm bolt that I didn't get from the original set of headers.
is there any way I can check if I will be having exhaust leaks before I get these installed??
