Supra's turbo/manifold direct bolton for IS300?
This is the epidomy of a newbie question.
Well can it be done? Is there enoght room?
What the compression on an Is300?
Anyone done this?
Where can I find more info on this subject?
Thanks, Hope you guys are just as good as the guys from Fresh Alloy(Nissan Site)
I'm not new to turbos, just the 2JZ. I presently drive an 95 240sx w/sr20det.
-Deez
Anyone done this?
-Deez
Nobody knows?
I thought this was a forum?
Any info would be great. I've been looking at the engine bay and evrything seems to be a little cramped.
-deez
-deez
manifold
i believe supra from 1995-and up will fit directly to
is300 or gs300 cuz thy share the exact same block...
the only thing that u hv to worry about is the room...if there's enough room to fit the manifold. but i'm sure it will fit all 2jz-ge
blocks. all 2jz-ge blocks are the same excepting the head cylinders, and of course, intake manifolds...especially on turbo's.
hope that helps
hope that helps
The MKIV exhaust manifolds for the supra will not I repeat will not BOLT UP to the head of a IS300 2jZ-GE motor... the port spacing and sizing if different on the GTE motor then the GE motor... so dont try it it wont werk..
the Manifolds bolt onto the HEAD not the block. and if you want to try to use a turbo kit from a GE motor then yes it should bolt up.. but dont try to use a GTE turbo kit cause you would have to mod alot to make it werk...
