IS300 CD009 350z Transmission Swap
Old 01-27-16, 07:08 AM
  #61
whiteis33
whiteis33's Avatar
http://www.supraforums.com/forum/sho...-Adapter-Plate
let's see how that kit turns out..
Old 02-01-16, 04:50 AM
  #62
airfed
airfed's Avatar
That looks like a pretty good idea. Cutting off the bellhousing is better than cutting the tunnel I guess. There's a guy in the tagged thread that says it fits nicely with two 2"x3" cutouts in the tunnel. He won't give off any information cause he's been burned on trying to help people. I still don't see how it sits high enough for everything to line up without some serious hammering to widen the tunnel. I have 2 is300's now and will give it another try if supra store can pull this off.
http://my.is/forums/f219/3-year-hiat.../550089?page=2
Old 01-02-17, 07:25 PM
  #63
airfed
airfed's Avatar
Collins has figured out how to make this work, does anyone have this trans mounted in? If so how does it work out? I've moved on to a Ar5 and it's great but still wanna see how the cd009 works out.
http://collinsadapters.com/index.php/swap-kits/is300-a340-350z-full-kit.html
Old 01-02-17, 07:34 PM
  #64
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
http://collinsadapters.com/index.php...-full-kit.html
They figured out how to get it to bolt up. They did not figure out how to make it fit easily.
It requires a lot of transmission tunnel "modification"
Then, the rear diff ratios are completely incompatible with it.
A friend was the first ever to do this. He may not like to admit it, but it was definitely one of those "I told you so" moments for me.
Old 01-29-17, 05:12 PM
  #65
SERIALN9NE
SERIALN9NE's Avatar
Fits fine. Completely integrated into the car with minimal tunnel work. Shifter same spot as stock. Small cut needed for housing (this car was MT) and transmission comes in and out very easily. Uses ANY OEM 350/370Z clutch, OEM tranny x member and modified OEM driveshaft.
Old 01-29-17, 07:49 PM
  #66
Stretch21
Stretch21's Avatar
^^^ always coming with the fire
Old 03-12-17, 05:01 PM
  #67
Ninjataco
Ninjataco's Avatar
So, the oem z34 cross member/trans mount fit in the is300 stock location? also what modification does the oem z34 drive shaft need to fit/work?
Old 03-12-17, 09:21 PM
  #68
Inst44635
Inst44635's Avatar
No. He means stock is300 manual cross member.
Old 10-14-19, 11:13 PM
  #69
airfed
airfed's Avatar
Looks like a few people finally got that big sausage biscuit cd009 to fit. I eventually went with an AR5 and a spec twin disk. I shred with it on 650whp with 10.5 MT drag radials. It fit like a OJ Simpson glove but I like it. Back in 2013 the AR5 was just a rumor haha.
Wyzdum
Build Threads
64
09-12-18 11:40 AM
gtech2
Performance
24
03-30-18 10:31 AM
LO 21
01-08-16 10:06 AM
RGW LLC
04-15-15 03:18 AM
Quick Reply: IS300 CD009 350z Transmission Swap
