Polished Trans Cooler
Old 01-22-09, 09:11 PM
  #31
sam430
sam430's Avatar
that's how I did mine. You can disconnect which ever line you want. of course ..that drawing u made is what I intended to draw..LOL.
Old 01-22-09, 09:14 PM
  #32
Euro09
Euro09's Avatar
Ok I guess I will disconect after the OEM then connect to the cooler then return to the Tranny. Anyway I appreciated
Old 01-23-09, 12:58 PM
  #33
sakataj
sakataj's Avatar
i take it you'll are art school majors? hehe just teasin. i been meaning to do this a long time ago, even talked to my mechanic a week ago bout it. soon i hope
Old 01-23-09, 01:17 PM
  #34
sam430
sam430's Avatar
It's so freakn' easy. from 1 - 10...I'll give it a 0 for difficulty. Buy extra hose about the same length (cheap). Cut off excess. The hardest part is mounting the cooler. I just tied mine - it's ugly LOL but who is gonna see it anyways.
Old 01-23-09, 02:00 PM
  #35
Euro09
Euro09's Avatar
Another question for u my man...WHY do we need another hose for ??? where does it needs ???
Old 01-23-09, 02:03 PM
  #36
Euro09
Euro09's Avatar
Check my drawing I have a master in Art
http://i230.photobucket.com/albums/e...ntallation.jpg
  #37
sam430
sam430's Avatar
U need another hose so it's easier to place your b&m cooler. With short hose, your limited. The hose will go from the B&M to the Tranny.
Old 01-23-09, 02:06 PM
  #38
Euro09
Euro09's Avatar
so the one they PROVIDED will be connecting to the Radiator ?? correct???
Old 01-23-09, 02:21 PM
  #39
sam430
sam430's Avatar
The one they provided is long enough to connect to the radiator or the tranny...it's just that when you cut it...it's not long enough to be used for both.
The reason I suggest another hose is to simplify installation. Plus the hose is cheap.
Old 01-23-09, 02:42 PM
  #40
Euro09
Euro09's Avatar
Got u. I saw some of our member using the STEEL line instead of that rubber hose so whats that all about ???
Old 01-23-09, 03:31 PM
  #41
sam430
sam430's Avatar
I guess they don't wanna worry about a leak... don't tighten too much Just enough will do and inspect for leaks. I use rubber. That reminds me...I need to check to see if any rubbing of the hose.
Old 01-23-09, 03:54 PM
  #42
Euro09
Euro09's Avatar
is there a particular one or we can use any of steel line ??
Old 01-23-09, 04:00 PM
  #43
sam430
sam430's Avatar
Yes...you have to use a particular steel line. I don't the specs on that.
Old 01-23-09, 04:25 PM
  #44
Euro09
Euro09's Avatar
damnit gotta be someone here using it
Old 01-23-09, 04:33 PM
  #45
sam430
sam430's Avatar
Check the sticky above on tranny cooler.
Quick Reply: Polished Trans Cooler
