Is300 5spd Tranny on 98-01 Gs300
Banned
How much would it cost to get the tranny of an IS300 5spd installed to a 98 and up Gs300????
from what i understand, U loose the Power mode, all u keep is the ASC and winter mode.
any info would be appreciated.
thanks,
thanks,
You WILL get a check engine light from the ECU feedback. There are a couple of ways you can install a manual tranny and maintain all the electronics on your car (...also VVT-i):
1) You might have to get an IS300 ECU also for the manual tranny to work.
2) Motec m800 and custom wiring harness
3) Pectel T6 and custom wiring harness
*) with option 2+3 you might as well ditch the drive-by wire.
Banned
thanx 4 the info.
I was thinking of going with the SRT stage 2-4.
I want 13sec's flat
But currently i have a gs400 with a lot of mods, so i will chop it and get a 300.
The question remains, if the costs of the tranny and all parts associated with is too high i might as well get a 00-01 to atleast have the tip-tronic atleast.
If it's have descent then 98gs300 and let the show begin.
V300, can you atleast tell me how much the V300 upgrade for a gs300 is going to run? 20g's?? i've seen it done on an Is300 for 20g's.
I know it's a lot of work an all, but i want that 6spd.
I want 13sec's flat
Banned
It should, i'm sure it will.
same engine,
I'm asking on the an estimated price for the job.
I want 5spd, or 6spd.
I know powerhouseracing.com have done stuff like that.
I just don't want a straight auto GS. (atleast E-shift)
same engine,
RGW LLC
IS - 1st Gen (2001-2005)
08-07-09 09:42 PM
