TC and LSD questions
Old 01-06-03, 08:50 PM
rominl
exclusive matchup
rominl's Avatar
Default Re: Re: Tom:
Originally posted by DaveGS4
I drove my GS without the LSD but WITH TC for almost two years, then added the LSD. The answer to your question is "it depends" .
Most of the time you'll get the benefit of the TC without the LSD. Definitely quicker off the line, but you can experience wheel spin (aka burnouts) depending on a number of variables including:
- grip of your tires (remaining tread, softness of tire compound, heated, etc)
- road surface (including hard straigh-line launch, dips in road, angle of launch uphill)
- other variables that impact the power output of your car (my GS runs much stronger in the cool weather, for example)
I would not hesitate to recommend getting the TC installed without an LSD. IMO it's by far the biggest bang-for-buck performance mod you can make to your GS. However, if I had the opportunity and means to do them both at the same time I would certainly go ahead and do it.
I honestly did not feel the need to get an LSD until I went to a quarter mile track with my GS. The track surface was less-than-ideal with lots of rubber and some fluid, and I had severe traction problems. Although I put on a good show for the crowd by lighting up our tires in a HUGE cloud of smoke, leaving burnt rubber all over the back underside of our cars , it didn't leave me with the good ETs I hoped for. I went looking for options for better traction immediately after that event and added the LSD and new wheels.
so dave, after you got the lsd, did you immediately feel better "grip" and power transfer to the wheels
this thread is soooo informative, i can't spend that much time now but tonight i am going to read everything over again to make sure i learn every single thing. you gotta love the technical aspect of CL
Old 01-06-03, 09:33 PM
Received 2,397 Likes on 1,571 Posts
I have the TC installed and no LSD. I can attest that I can light up my rear 275s now where I couldn't before!! It's a hoot.
I also have a TRD LSD sitting in my basement waiting for me to find someone who can install it!
Old 01-06-03, 10:27 PM
UTGS400
UTGS400's Avatar
I have a TC and LSD and I can not light up my 265's without power-breaking. If I simply slam the gas down, the tires will squeal for about 1 second then catch.
Old 01-06-03, 10:36 PM
I don't see how an LSD can help in a straight line.
Old 01-06-03, 11:28 PM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,245 Likes on 1,363 Posts
Default Re: Re: Re: Tom:
Yes. I would not necessarily call it grip, but a more even launch force as the torque builds at launch.
You can still break one wheel loose in a straight line and smoke the tires with an open diff. A prime example is what happened to me at the drag strip (straight line) which caused me to get the LSD.
UT - with my new larger wheels/tire contact patch and LSD I now have exactly the same traction experience. Every now and then I''ll catch a good one and light em up, but most often it's a little squeak and I'm off.
Old 01-06-03, 11:40 PM
futuregs
futuregs's Avatar
Default Re: Re: Re: Re: Tom:
All u need is an LSD for your "New Years" Feet that you have....
I know your TC is that Steel Cockatiel.....
Old 01-07-03, 02:27 AM
UTGS400
UTGS400's Avatar
Someone correct me if I'm wrong, but an open differential sends the power to the wheel with the least resistance. With an LSD, power is sent to the wheel with the most resistance or at least distributes the power more equally. As Dave pointed out, without an LSD the power is sent to one wheel causting major burnouts. But with the LSD, as soon as one wheel begins to slips, power is transferred allowing the tires to grip and the car to go.
Old 01-07-03, 02:14 PM
mumbles
mumbles's Avatar
rominl,
Just as an FYI, the two readily available LSD's are the RMM, and the TRD. The difference between them is twofold;
1) RMM has lower gearing than the TRD, ie; it take a "lower" number of revolutions of the drive shaft to rotate the axle one full revolution. This equates to slightly better off the line performance, an a slight loss in top end speed. I say slight, because the difference in the gear ratio between the two is not that great.
2) This is the biggie in my book. The RMM is the entire rear differential housing whereas the TRD is just the internals. What this means is that virtually any competant mechanic can install the RMM while the TRD is best left to real transmission experts. They will have to be intimately familiar with using shims and spacers to get everything lined up perfectly, otherwise the LSD will meltdown to an $800 - $900 pile of pot metal.
Both Bitkahuna and myself still have our TRD's sitting in the box due to the difficulty of finding someone competant enough to install them. If you have known high-end tuners in your area, you should be o.k. with the TRD, if not, I'd recommend going with the RMM.
Hope this helps!
Old 01-07-03, 02:23 PM
mumbles
mumbles's Avatar
Bit,
The LSD sends power to the wheel with the most traction, so say you take off from a light doing a burnout (not that you would ever do such a thing), and your right wheel is on a better portion of pavement traction-wise then the left wheel, it will get the majority of the power. But, say your right wheel hits a puddle or patch of ice and starts to spin, the LSD will transfer the power to the left wheel thereby "limiting" the slipping and maximizing power tranfer. But, like I said, since you never do any burnouts, you should probably just sell your LSD to rominl...
Old 01-07-03, 02:30 PM
gs4304u
gs4304u's Avatar
Would it be better for me to go to a Lexus dealer or reputable local mechanic for the installation for the TC or LSD? And what would be the charge?
Old 01-07-03, 02:32 PM
DaveGS4
Forum Administrator
DaveGS4's Avatar
One point of clarification is that the RMM is the exact same thing as the factory Supra TT LSD, just rebadged (like they do with the brakes)
There are a number of other threads on CL debating the differences/merits between the two if folks are deciding which to buy (use search ).
Eric - I've corresponded w/ Bit on the install here in Charlotte and placed another call to Hendrick today. Maybe we can work out a two-fer with them once I confirm the mechanic.
Old 01-07-03, 02:40 PM
mumbles
mumbles's Avatar
Dave... is that you Dave? Long time my friend! Bit and I managed to get some possible connections here in ATL from the Supra guys... have to see how they pan out. Not that a "leisurely" jaunt to Charlotte and a visit to Dave and his Somniplex wouldn't be enjoyable!
Old 01-07-03, 06:53 PM
JacobT
Guest
Posts: n/a
Here are the differences between Torsen style RMM LSD and clutch type TRD LSD.
Torsen style is gear driven torque bias differential while the TRD unit is clutch driven full lock bi-directional differential. Torsen style will send power to different rear wheel proportional to the traction while the clutch type is either fully locked or fully un-locked. The TRD unit can handle higher HP than the Torsen type.
The TRD unit is a well desiged directly drop in piece. No shim is needed while doing the swapping. My tech. was surpirsed to see the unit fit perfectly into the pumpkin without any shiming. Just remember to use the LSD diff. oil. I've had the TRD LSD installed for 2 years w/o any problems.
Old 01-07-03, 11:54 PM
rominl
exclusive matchup
rominl's Avatar
rominl,
Hope this helps!
great info man, thanks man, there are just so much i have to learn on this
Old 01-07-03, 11:57 PM
rominl
exclusive matchup
rominl's Avatar
ummm ok... so from from what you said, jacob, does that mean if i don't plan on putting sc or turbo on my car, the rmm should give me more benefit?
Quick Reply: TC and LSD questions
