TC and LSD questions
#31
Originally posted by JacobT
[snip]
The TRD unit is a well desiged directly drop in piece. No shim is needed while doing the swapping. My tech. was surpirsed to see the unit fit perfectly into the pumpkin without any shiming. Just remember to use the LSD diff. oil. I've had the TRD LSD installed for 2 years w/o any problems.
[snip]
Originally posted by rominl
ummm ok... so from from what you said, jacob, does that mean if i don't plan on putting sc or turbo on my car, the rmm should give me more benefit?
Originally posted by mumbles
1) RMM has lower gearing than the TRD, ie; it take a "lower" number of revolutions of the drive shaft to rotate the axle one full revolution. This equates to slightly better off the line performance, an a slight loss in top end speed. I say slight, because the difference in the gear ratio between the two is not that great.
You are correct that the TRD has a "lower", numerically higher, ratio of 3.76 vs 3.26 and you are also correct about the result (performance, less top end) but I don't think I understand your example. If the driveshaft spins once and you have a 3.76 differential ratio you need to spin the drive shaft 3.76 times to get one revolution of the wheels. With a 3.26 it only turns 3.26 times for every wheel revolution.
You want lower gearing to a point. Then as your car makes more and more power you want to start moving to higher gearing to extend the amount of time your engine spends in the peak power band.
Originally posted by Bitkahuna
I don't see how an LSD can help in a straight line.
#32
Northern California Regional Officer
think of it this way. A car burning rubber with no LSD lays down only one black streak on the road, while an LSD car lays down two black streaks. Your traction is doubled if both tires are grabbing.
Ive got the the RMM LSD, TC and valve body upgrade. On a grippy surface launching at around 1500 rpm I will still spin the tires for a few feet before grabbing. On a smooth asphalt surface and a little more launch rpm, I can spin "both tires" for about 15-20 feet.
I have Michelin Pilot Sports 285/30-19's w/10 inch rims out back by the way.
As far as the gear ratio debate is concerned, I'd be curious to see how easily someone with similar mods as me can break the tires loose with the main difference being the TRD 3.26 gearing. Who out there can compare launching results with what I just described on my 3.76 geared car?
One of these days, I will try to get my car to the dragstrip as soon as summer rolls around and will post my 60 ft. times.
#33
Is the GS4 speed, rpm, or drag limited? Also, did anyone recalibrate their speedo when they changed their gearing?
#34
Speedo Info
It's not necessary to recalibrate the speedometer as it reads off the ABS sensors & not the tranny. As long as U don't alter the rolling diameter of your wheel/tire combo ( roughly 25.3", I recall ) by more than maybe 5%, things will be OK. I've verified my speedo after the RMM LSD install by several other methods ( mileage markers, another car's speedo & lastly by a State Trooper's radar ). Fortunately, the last method was via my friend who happens to be a Trooper & NOT by a ticket ( but that's another story!! ):eek:
FWIW - the GS is speed-limited via a 149 mph governor ( soft limitation engineering ).
FWIW #2 - I've been asked to compose a writeup of the RMM LSD by LS400 & hope to have it to him by the end of the month ( deadline's Valentine's Day ). It's been over 2 years since I installed it so there'll be no pics but I'll have some subjective views on things as well as some objective data from the G-Tech Pro & the dragstrip.
#35
Guest
Posts: n/a
True or false. RMM 3.76 gear ratio can light up your rear wheels easily but the different gear ratio will confuse the tranny ECU, so you may hit 6500 rpm rev. limiter during hard accelerations.
I was wondering if anyone has opened up the RMM unit and swapped out the ring gear with stock 3.26 gear? By doing so, you'll get a Torsen style LSD without worring hitting the rev. limiter
#36
If you're interested to know why and a little gear tech, read on:
The majority of hypoid ring and pinion gears for automotive differential applications are designed and manufactured as unique, matching sets. These gear sets are machined and "lapped" together and assembled as a unique pair. In this case, a different ring gear with identical specifications as the "orgininal" ring gear could not be installed in a differential with the "original" pinion gear; if it was, the result would be excessive gear noise and premature failure. A select few higher-end automotive manufacturers such as Jaguar (I don't know about Toyota/Lexus) employ a more sophisticated and flexible hypoid gear manufacturing process called gear grinding. This process allows any pinion to be matched with any ring gear but oinly within a specific manufacturing lot of identical specification / ratio ring and pinion gears. Regardless of manufacturing method (lapping or grinding) for a hypoid gear, a ring gear could not be swapped into a carrier than contains a pinion gear of a different ratio gear set.
#38
Interestingly enough, the stock 3.26 gear differential ratio is fairly "optimal" for a stock or mildly modified GS4 quarter mile dragstrip run given the transmission gearing / transmission shift rpm / drive tire diameter / differential ratio.
In general, most serious drag-racers set up their vehicles to run through the end of the track at or just past peak HP (which occurs ~5800-6000 rpm in the GS4) while in the 1:1 transmission gear ratio (4th gear in the GS4) for optimal ET. The input variables include transmission gearing, transmission shift rpm (associated with usable engine rpm) / drive tire diameter / differential ratio.
It just so happens that most stock / mildly modified GS4 run through the end of the quarter mile right at the top of third gear (1.424:1 ratio) which saves a timely shift into fourth gear. For comparitive purposes, a 3.76 differential ratio-equpped GS4 will run through the end of the quarter mile ~5100 rpm (close to intersection of hp and torque curves) in fourth gear.
In my relentless pursuit of often useless information, I put together an Excel spreadsheet that will calculate mph in any transmission gear and engine rpm given an input of tire diameter (or tire sidewall info) and differential ratio for the GS4. This spreadsheet also reveals what rpm the engine will move to after a transmission shift for the GS4. If you are interested in obtaining a copy to play with or host, PM me and I will email it to you.
#39
Ok ok guys I get it - an LSD is useful in all situations! Thanks for clubbing me over the head with it. I feel much better.
And a mighty fine LSD it is sitting in my basement!
#40
One of the things that nobody really hit on with the LSD is how much better the electronic traction control works in slippery situations with an LSD.
Here is the situation:
At a stoplight turning right, slight snow cover (or rain) on inside of turn. You hit the gas, inside tire spins, traction control brakes right rear brake, evectively putting forward torque on the outside (left rear) tire due to the way an open differential works. The actual result is that the traction control puts very little usable torque to that outside tire that has traction, you end up lighting up the traction control, without making much forward progress, despite the efforts of the traction control.
With a LSD out back, the inside tire starts to try to spin, LSD torques outside tire, evening up the rpm of both wheels. If the torque is too much for both, sliding both tires will set off the traction control. The car with the LSD will accelerate around the turn much better than without the LSD any time there is a difference in left to right weight distribution and any time there is a difference in road surface traction from left to right.
