Anyone do a full dual exhaust on a GS4?
I do.... My car has custom made headers, down pipes, high flow cats, X-pipe, duals back to a couple Apex-i mufflers. It cost an insane amount of money to get it done.
Its recommended to have a balance pipe for engines that has 2 banks of cylinders for scavenging. Scavenging is when the exhaust pulses helps increase exhaust velocity for efficiency, therefore, more performance.
So is it for sound only? I asked some local muscle car guys and they told me the purpose of the x-pipe was to alter the sound characteristics, not to add more power. They said a lot of muscle cars have headers that are not equal on each side, so the X-pipe helps to balance them out and sound better. I am curious if anyone has done a before/after dyno with and without an x-pipe.
I have had the S&S headers, 100cell cats, full dual 2.5 stainless exhaust with X-pipe, burns stainless resonators and GReddy Evo2 rear section on my car since 2006.
This is the best sounding setup I have tried - I have tried 4-5 other setups and they all had issues.
The X-pipe adds power and makes it sound better as well - you can easily google the theory.
XPipe design IIRC came out of NASCAR (Dr. Gas), nothing to do with noise, but to increase scavenging of the opposite exhaust pipe. A Y-pipe does much of the same, think of it as a very long X pipe, but most y-pipes remain single where our 2GS4's go into a muffler than then back into dual. So there is lots of room for improvement there. The Y pipe properly designed has a higher scavenging effect, but if the pipe is too small/large it will affect power.
I read on (I think Lextreme) that the size of of the Y-pipe on the GS/LS is critical to power. Larger will increase PEAK power, but it hurts the midrange everywhere. And the gains aren't much either.
So be careful on increasing pipe size, and if you can have a long X (almost like 2 pipes welded together for a short distance, say 6-9 inches instead of the typical x-pipe 2-3 inches) it has a stronger effect. And might be a good replacement for the first muffler in the 2GS4.
If you want noise, great sounding noise, go true dual with no balance pipe/X-pipe. Will have more power than stock y-pipe/muffler. A well designed X is still best for power.
go4dabukz
Performance
05-30-07 09:04 AM
