Old 12-16-14, 12:44 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Lexus IS Engine and Powertrain Guides
Print Wikipost
[Installed] Injen Short Ram Air Intake
Old 09-16-13, 06:24 AM
ddb
ddb's Avatar
Originally Posted by sarcoptic
I don't think warm air is really an issue. When you remove the stock air box there is an inlet pipe that runs from the front of the car into the area where the exposed filter is sitting therefore I would think during acceleration you would be forcing outside air right to where the filter is. The car definitely sounds louder with the intake during acceleration. Here is my takada setup:
Your setup looks nice and clean, and you also have the heat shield so it should work better than those that don't have it. I know the stock air box has the intake from the front, but as a general rule, you should always avoid the intake from taking hot air in, so at low speeds and idle you are sucking in hot air from the engine bay, unless you use the shield.
Yours looks like a good solution.
Thanks!
Old 09-16-13, 08:38 AM
sarcoptic
sarcoptic's Avatar
No problem...also do some looking for coupons and such...I picked mine up fro autoanything for $174 shipped.
Old 10-01-13, 07:55 AM
Fsportlex
Fsportlex's Avatar
not utilzing the stock air box or F sport airbox that will come out soon will result in a lot of dirt and grim in your engine bay and the hot air as described even with the heat shield. I had the same intake and took it out after a week and returned it becuase of this problem. Joe Z has the intake tube that goes into stock air box which connects direclty to front intake and resovles this problem.if not wait for the f sport intake to come out. Looks good but just some food for thought
Old 10-01-13, 10:10 AM
cj0
cj0's Avatar
Where did you guys purchase your intake?
Old 10-02-13, 06:25 PM
corradoMR2
The pursuit of F
corradoMR2's Avatar
^^^^ check out autoanything.com
Old 10-03-13, 10:58 AM
juvi22003
juvi22003's Avatar
Got mine from Rare Snare
Old 10-08-13, 04:41 AM
Goodlife
Goodlife's Avatar
Can't wait to order this for mine, needs a lil more power
Old 10-09-13, 10:20 AM
sloosh
sloosh's Avatar
Originally Posted by ocis350f
There was definitely a substantial increase in HP and Torque.
Got any numbers on that yet? I don't think you'd see anymore than a few extra WHP, if that.
Old 10-10-13, 02:05 AM
Exeon
Exeon's Avatar
Are people getting it properly tuned with this intake? I can imagine it running rich
Old 10-11-13, 01:29 PM
Stitch626
Stitch626's Avatar
Don't believe there is a tuning program available yet so I can't imagine so
Old 10-15-13, 10:04 PM
mahtbeezy
mahtbeezy's Avatar
tried to install mine today and the check engine light stayed on. also the traction control stayed off.
when I installed the stock back on the lights all went off. can anyone help?
Old 10-16-13, 09:16 AM
carderoni
carderoni's Avatar
Had the same issue when I installed a Joe-Z intake. It was likely caused by the MAF adapter or a vacuum seal issue. Either way, this resolved it:
Unplug your battery and drain it for good measure. Just stand on the break pedal and press the horn a few times. Reinstall the new intake and make damn sure the vacuum line that connects to the intake tube is on there tight, that the clamps on both ends of the intake tube are on there tight, and that the MAF adapter is connected properly. Reconnect your battery and start the car. It may shut itself off after a couple seconds of idling. Restart it - now it should stay on and your check engine and trac lights should be gone.
Old 10-16-13, 12:04 PM
ocis350f
ocis350f's Avatar
Looks great Sarcoptic. I also kept the little "funnel" installed, which I think should help a little.
Old 11-18-13, 07:07 PM
ethotie525
ethotie525's Avatar
Hey guys CAI looks really nice. On a lease does this void any warranties?
Old 11-18-13, 08:28 PM
Stitch626
Stitch626's Avatar
CAI are a pain in the *** you really don't need it and the short rams are better believe me I had a CAI on my civic and never again lol
Quick Reply: [Installed] Injen Short Ram Air Intake
