Twin Turbo GS400 Update
come on....
u serious???
i thought u got a good deal???
37g's doesn't sound 2 good 2 me
good luck on that *ish, just be responsible......
TRUST when u got that much power u get carried away..
Soon my RS4 will be up their with u
u serious???
![Roll Eyes (Sarcastic)](https://www.clublexus.com/forums/images/smilies/rolleyes.gif)
$37,000 for a twin turbo install???!?
I hope they included some complimentary Vasoline with that raping they just gave you!
Please tell me they did more than just stuck 2 turbos under the hood? Maybe an upgraded fuel system, boost controller, and a few other accessories?
For 37k I'd also hope they did a transmission rebuilt or upgrade so that you won't be needing a rebuilt after 5k miles.
...unless of course the GS400 auto trannys were built to withstand 600+ pounds of torque... but honestly I've never once in my life seen a manufacturer (other than Allison w/ their diesal trannys) go to the trouble and expense of building their automatic trannys to withstand twice as much torque as they'd need to from the factory.
So what all did you get for 37k?
no guys,
that's what he paid for just the TT setup + goodies(tranny rebuilt etc..)
not sure about the Blitz boost controllers,etc...
but either way, way too much money
like i said before, i would have rather done the v300 upgrade,
that would have run 26k installed and everything,
but hey its all about taste, and YOu Mariusz, just bought it
i meant that in a good way
hehe.
good luck , lets c some 1/4mile vidz
its a littel more involved than slapping a couple of spinners on the manifold. here is the list of equipment......
- Race built blue printed/balanced 1UZ-FE engine with SRT spec. lowered compression forged pistons, all new bearings and seals
- Race built auto tranny with Raybestos Blue plate clutches, SRT calibrated valve body, all new seals and custom springs
- Blitz SBC-iD boost controller
- Blitz Power Meter
- Blitz Turbo Timer
- Blitz Blow off valve
- Twin Turbonetics T3 turbos built to SRT specs. intregated waste gates with DP auctuators
- Spearco front mount Intercooler with SRT Spec end caps (13"H x 3"D x 24"W)
- Dual 2.5" T304 SS mandrel bent downpipes
- RC engineering 440cc injectors
- Aeromotive Fuel Pressure Regulator
- Aeromotive Fuel Pressure Riser
- NGK Racing Platinum Plugs
- SRT Air/Fuel ECU
- Pillar mounted Lunar style AutoMeter Boost Guage
- Twin Individual mandrel bent turbo Intake pipes
- All hard piping for turbo to IC to TB are 3" mandrel bent and bead rolled
- SS braided Turbo oil supply lines
- SS braided Turbo drain lines
- SS braided Fuel lines
- Walbro 255lph high pressure intank fuel pump
- Four layer reinforced silicone connectors
- Custom built Turbo manifolds for each bank
- TRD Thermostat
- Dual Fluidyne radiator fans
- All crucial items are heat shielded
- GReddy front lip spoiler
- Permacool Oil cooler
- Permacool tranny cooler
- Tein FLEX suspension with EDFC.
- TRD Limited Slip Differential
- Maximum safe boost using Premium pump gas is 1 bar (14.7 PSI)
- All factory ecu safe guards in place including all functions of the OBD II
- All accesories are still functional including VSC
- serialized, recorded, SRT signature authenticated plaque with Scorpion keyring and emblem
- Factory catylytic converters are retained in their original locations (street legal)
- Price: $34,995.00 +tax includes installation and dyno tuning
- Blitz Power Meter
- Blitz Turbo Timer
- SRT Air/Fuel ECU
- TRD Thermostat
I certainly admire the raw, unadulterated power combined with the grace of a GS4, but I think for $37K + tax, I'd be grabbing a new G35 Coupe or something as an extra car rather than souping up the GS.
Congrats, nonetheless!
Guest
Posts: n/a
It's still too much.
C'mon $37K. I bet not too long from now the abilitiy to produce these will be much easier to achieve and the price will drop.
I bet there's a huge profit margin on this. Of course, I know nothign about turbo installs or anything..
- Blitz Power Meter
- Blitz Turbo Timer
- SRT Air/Fuel ECU
- TRD Thermostat
- Blitz Power Meter
- Blitz Turbo Timer
- SRT Air/Fuel ECU
- TRD Thermostat
The only things worth much of anything is the tranny rebuild, turbos, and motor rebuild (balancing, etc)
Nice way to make a standard TT install w/ all the accessories sound like it's worth 35 grand though!
Heck, even Mr. Lingenfelter himself never charged that much for so little... and he's pretty much considered the god of all tuners.
