2jz ecu cap problems
Hey dudes, Ive been reading about bad capacitors in the 1jz ecu's and other models, do the 2jzgte ecu's have these issues too? I'm having the most weird issues ever on my 95 gte swap...
my power is very inconsistent lately. under half throttle, i boost and drive fine. under heavy throttle, I break up. even in neutral, i cant rev past 5k if i floor it. some days its 4k, some days its like 6k. i figured it was a coil pack issue, but i replaced all 6, replaced plugs, and used heat shrink and still no difference. when i watch the boost gauge under high throttle, the boost drops off after hitting normal boost levels. under light throttle, i hold boost perfect.
here are the caps and quantity from my 95 aristo 2jz-gte ecu
10uf 50v x2
15uf 35v x1
47uf 63v x2
100uf 10v x1
100uf 100v x1
220uf 16v x1
here is a great link on replacing caps for the other lexus ecus, which are pretty similar to the gte
https://www.clublexus.com/forums/ls4...capacitor.html
10uf 50v x2
15uf 35v x1
47uf 63v x2
100uf 10v x1
100uf 100v x1
220uf 16v x1
StuntKing
Performance & Maintenance
13
12-13-12 10:03 PM
