Greddy vs Takeda Intake for 3IS.
#34
Outside sound clip posted:
2014 Lexus IS350 F-Sport GReddy Intake - YouTube
1 clip taken in an adjacent car with windows rolled down. 1 clip is stationary from outside.
#35
http://www.frsport.com/GReddy-125190...2_p_51145.html
Not sure if you can order it from here but this is where I got mine.
#36
It shows which parts don't fit perfectly, since it was designed for the 2IS. The main fitment issue is the vacuum tube (4th photo in the DIY), but this is easily fixed by getting a better hose clamp for a couple dollars. Other minor issues are some wires clips that you won't be able to clip back into place, so the wires will hang a bit looser. Not a bit deal though, and you can use some zip ties to secure them if it bothers you. If those issues won't be a problem for you, then go ahead and order the intake. At this moment, it doesn't look like any companies are coming out with intakes designed specifically for the '14 IS, except F-Sport & Joe-Z.
#38
Can anyone please explain to me what this "loud mode" is? Is it just a pulled fuse to help the exhaust sound better?
I know in the Aston Martins if you pull fuse 22 it opens up the throttle and the exhaust sounds better all the time.
#41
Loud Mode?
Loud Mode?
