suggestions for an intake. ..
Old 10-15-13, 11:46 PM
deeziex626
deeziex626's Avatar
Default suggestions for an intake. ..
Hey guys I'm still a newb to all this, ive had my is250 for a little over a year now, planning to add an intake... was thinking f-sport? any recommendations or suggestions would be much appreciated :]
Old 10-16-13, 09:11 AM
SeanO
SeanO's Avatar
F -sport or Joe-Z are the most common. Most intakes are all around the same price. Subtle differences. The F-sport comes with a modified box similar to your stock one. Other aftermarket intakes will have mounting brackets and a cone style filter.
Old 10-16-13, 09:49 AM
deeziex626
deeziex626's Avatar
Ooo... good to know, thanks SeanO!
Old 10-16-13, 02:02 PM
xZhongChen
xZhongChen's Avatar
I have a JoeZ with a AFE Drop in Filter. Costed less than all the other intakes you can get, produces the same result
Old 10-16-13, 07:47 PM
deeziex626
deeziex626's Avatar
Oh really? Hmmm im kinda leaning more torwards the f-sport just cuhs its oem, but I'm still undecided. But thanks. Is it true you get more mpg after u install an intake?
Old 10-17-13, 08:05 AM
xZhongChen
xZhongChen's Avatar
i did notice a increase of MPG, but its not much. JoeZ is pretty much a OEM intake, as it utilizes the stock air box. I am actually thinking of getting a FSport Air Box just for the more aggressive sound
Old 10-17-13, 05:09 PM
4grDrvr
4grDrvr's Avatar
Agreed! Have this setup as well! Get compliments all the time
Old 10-18-13, 07:23 AM
xZhongChen
xZhongChen's Avatar
Do you use the Stock intake box or an FSport Intake Box?
To get it from the dealer, it costs 90$.
Old 10-18-13, 11:46 AM
UniSlayEX
UniSlayEX's Avatar
still cheaper but most just cut the stock box.
Old 10-18-13, 01:57 PM
projectdna
projectdna's Avatar
Joe Z intake pipe + aftermarket drop-in (read: OEM-sized) filter (K&N, AFE) + F-Sport lower intake box.
easily less expensive than the full-on F-Sport intake system.
Note that you can buy the lower portion of the F-Sport intake box separately, while the top of the F-Sport intake box is the same as the OEM intake box.
Old 10-21-13, 04:27 AM
A_Grasso
A_Grasso's Avatar
if you want something really loud, go with the Takeda, AFE, AEM, K&N, or Injen. I know you mentioned keeping it legal, so I would either go with the F-Sport, or JoeZ pipe and add an aftermarket air filter. I also noticed your username has 626 in it? You can come out to the 626 Friday night meets and ask some members if you can sit in their cars to hear their set-ups. Hope this helps!
Old 10-21-13, 08:56 PM
joshua28
joshua28's Avatar
I've been using the Takeda for a couple months and no issues at all. The sound is quite loud, very aggressive. If you want loud, go with the Takeda! It's also a lot cheaper than the F-Sport that would give you a lil bit more performance over sound. Choose base on what you want. Takeda also has a dry filter so you don't have to oil it. You can also check out the Greddy's or the AEM intakes. All the short rams will provide similar minimal gains but with great improvement in sound.
Old 10-24-13, 03:01 AM
IS350AWD
IS350AWD's Avatar
If you get an intake, should you get the exhaust as well? A person tried to make the argument that if you get a different hole up front (no pun intended...) you need to fix the air exit (exhaust) otherwise you're not really helping/changing anything.
Thoughts?
FordGT08
Performance
03-28-13 12:23 PM
FordGT08
Performance
14
03-02-13 12:51 PM
MGLane
Performance
10-01-10 11:18 AM
aliu603
07-27-09 11:39 AM
Quick Reply: suggestions for an intake. ..
