help with wish list for GE turbo upgrade!!!!
Old 10-29-13, 08:23 PM
6chuchu6
6chuchu6's Avatar
Exclamation help with wish list for GE turbo upgrade!!!!
after doing some research iv compiled a list. this is what i got. please if anyone could help with anything else or anything i don't need. you would be awesome. and i would just all around appreciate it.
T57 / .82 hotside
stainless manifold
wastegate / dumptube
downpipe
FMIC
IC piping
BOV
Emanage/Wiring Harness
660CC Injectors
Fuel Pressure Regulator
Turbo Blanket
Upper intercooler pipe
Air Filter
AEM Wideband
Boost Gauge
Oil Feed
Oil Return
Misc Clamps / Couplers \
Misc Wiring / Hose / Fittings
Heat Shield x 2
MAP Sensor/pigtail
2jz-gte pistons / rods
OEM rings
OEM Headgasket
Clevite Tri-metal bearings
Hone, surface, clean, check
ARP Head studs
Gates Timing Belt
Break in Oil, Filter, Coolant
Toyota FIPG
O-rings, Seals, Gaskets
Old 10-31-13, 06:45 AM
6chuchu6
6chuchu6's Avatar
just trying to see if im on the rite track
Old 10-31-13, 08:20 AM
tjmhillz
tjmhillz's Avatar
Seems like your on the right track. What are your hp goals. Here was my set up.
GTE Internals.
GTE headgasket
Boost controller
AF wideband
arp headstuds
bm trans cooler
turbonectic 60-1 turbo
turbonetic wg
turbonectics log mani
550 cc injectors
walboro fuel pump
aem fic
You can get get custom piping done or piece together piping along with fmic. As far as your emanage. Are you doing the install/tuning yourself? if not I would talk to your tuning/builder and see what they are comfortable with tuning.
Old 10-31-13, 10:47 AM
6chuchu6
6chuchu6's Avatar
Well I'm looking for about. 400+ at least it's the plan. Im going thru a shop. And the one last question I would have is that would all tis work with the auto transmission.
Old 10-31-13, 11:01 AM
tjmhillz
tjmhillz's Avatar
Yes it will work on auto trans. I was auto as well. You may have to upgrade your valve body to protect the trans though. Also you we def need a trans cooler to keep the temps down.
Old 10-31-13, 07:53 PM
6chuchu6
6chuchu6's Avatar
sweet i will start looking for parts now. i really appreciate the help.
Old 11-01-13, 05:47 AM
tjmhillz
tjmhillz's Avatar
Np and happy boosting.
Old 11-04-13, 10:37 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
Junk the emanage.... And the t57 is tiny... You will hate your life every second of trying to use it... Aem ems... As for turbo, pte 6266 and don't look back...
Old 11-12-13, 08:27 AM
6chuchu6
6chuchu6's Avatar
from what i have been reading the pte6266 sounds pretty good. im assuming thats what your running.
Old 11-12-13, 08:44 AM
mitsuguy
mitsuguy's Avatar
Nope, 6765 here, but I wanted overkill... I will be close to the limits of a 6266, and 6466 are all ball bearing which is nice but $$$$ next logical choice and had a good deal was the 6765... Billet compressor, just not turbine...
Old 11-15-13, 06:38 PM
6chuchu6
6chuchu6's Avatar
so logical>6765
but 6266 and 6466 if not so expensive > the ******
are you happy with the 6765? would you recommend? any information would be awesome. thank you for your help
Old 11-16-13, 03:55 AM
mitsuguy
mitsuguy's Avatar
I'm very happy with the 6765, spool isn't terrible aside from 1st gear, dead stop... I'm dynoing the car Sunday, the goal is 450-500 on a Mustang Dyno... I still need a secondary fuel pump for much more...
Old 11-19-13, 01:19 PM
AZTurbo
AZTurbo's Avatar
For 400 whp I would go with either a 6262, 6265 or a 6266. This will give much better power band down low for the street and will still support 500-550 whp.
Old 11-19-13, 01:22 PM
mitsuguy
mitsuguy's Avatar
Correct... If 400 was all I wanted, I would have gone 62mm, just dyno'd exactly 500 whp, and plans for more this winter...
Old 11-21-13, 07:14 AM
6chuchu6
6chuchu6's Avatar
oh nice!!!!!! super pumped to hear the outcome.
Quick Reply: help with wish list for GE turbo upgrade!!!!
