Exhaust Mods - Regrets?
had the tanabe on the 99gs300, loved how it sounded on load. later added the megan y pipe, made it sound a little bit more raspier and throatier...
the same tanabe but on an 01gs430, first v8, thought my car was f***ed up, but the odd rumble is suppose to be normal! either way, sounded good. now installed the megan y pipe modded from an sc430. it quiet it down, but the growl is coming back with the pipe "breaking in". however, now it has a mid-to-high pitch rasp noise on load at 5500+ rpm. friend thought i boosted the motor...
I removed those 2 long resonators on my 400, kept the one just after the Y. Cabin sound hardly changed, just a bit louder when you step on it. Gives it a decent growl from outside though.
OP... exhaust on a GS unless FI does nothing but change tone without any added performance. On a 300 you will loose power from any larger than stock piping. on a 400 no power loss before 2.36 anything larger No BUENO.. restriction on the 400 is the headers, replace with PPE/S&S and gain lost power. axle back would probably be the best choice..
To answer your question, Yes i regret trying out 4 different set ups before going back to OEM..
no drone from resonator delete
Hello, I have a GS4 and wanted it to sound like a V8. I had a local muffler shop delete the 3 resonators and keep the stock mufflers. Sounds GREAT and not loud at all in cabin...no drone. Easy mod and worth it
