MidPipe on AWD, Confused! HELP!
Old 10-26-21, 10:53 AM
cdnb
cdnb's Avatar
I have a 2008 IS250 awd as well and as far as i can tell my stock mid pipes are the same on either sides as well and im extremely confused.
Old 10-26-21, 11:02 AM
MikeFig82
MikeFig82's Avatar
They're not the same. If under the car looking up near the front drive shaft for the front differential. There is a bend to clear it going to bank 2 exhaust manifold.
https://www.clublexus.com/forums/per...is250-awd.html
Old 10-26-21, 01:56 PM
cdnb
cdnb's Avatar
how much would the customization normally cost??
Old 10-27-21, 11:35 AM
JaeISF
JaeISF's Avatar
You can install a rwd mid pipe on an awd, all is needed is to modify the driver's side pipe. I've done this on mine using a rwd, it's cost me around $350.
Old 10-27-21, 11:39 AM
cdnb
cdnb's Avatar
awesome thanks that gives me a general idea!
Old 10-27-21, 11:44 AM
JaeISF
JaeISF's Avatar
no problem, I'll have to redo the midpipe now since ppe headers are installed it got raspy. Perfect time to do a true dual exhaust. Just know that the passenger side pipe will line up, just not the driver side.
Old 10-27-21, 02:02 PM
MikeFig82
MikeFig82's Avatar
From this picture you posted do you think there is a possibility of a small exhaust leak? There seems to be some soot that has marked both flanges. Did you experience some raspiness once this was done on stock manifolds? Try adding double gaskets on the flanges to get a better seal. The aftermarket one could be a little warped. Also it may trigger a rear O2 sensor code down the road.
Old 10-27-21, 09:29 PM
JaeISF
JaeISF's Avatar
These pictures are 3 years old and I'm only using them as reference for awd owners, the gaskets that came with the invidia arent great so I replaced them with aftermarket gaskets from ebay and that did the job and since then no issues. I've only replaced them earlier this year once I had ppe headers in. I had o2 sensor codes show up a few years ago after the first week of install for the invidia. There was no raspiness since I didn't touch the manifolds at the time and my setup was invidia midpipe and f sport axleback. Don't worry I know what I'm doing.
DB14IS250
Performance
09-12-18 10:26 AM
Jason3is
03-18-18 05:33 PM
Boost786
Suspension and Brakes
07-28-15 07:31 AM
24herbs
Performance
06-01-15 08:30 PM
chippy1202
07-30-14 03:55 AM
Quick Reply: MidPipe on AWD, Confused! HELP!
