Boosting with the twins... is250 turbo build
Old 01-24-14, 07:25 PM
  #286
Gville350
Gville350's Avatar
As an oil feed line and possible return line, probably. I'd like to see if someone knew which bung is pre or post-filtered oil. I'm trying to look through pics on the net right now and no luck as of yet.
Old 01-24-14, 07:32 PM
  #287
e46m3lol
e46m3lol's Avatar
If one is pre and post filtered oil would that mean that only one is a pressurized line? I'm buying a bung tomorrow morning to see if I can get pressure from the bottom one.
Old 01-24-14, 09:02 PM
  #288
Gville350
Gville350's Avatar
^Both will be pressurized, because the oiling system in the motor is sealed.
To definitively know which is which, we would need confirmation on which of the two ports that leads to the two small ports (see 12101C) in the pan sub-assembly (12101) that leads to the top-end of the motor. The one that leads to the top end of the motor is the filtered port.
Problem is I cannot find a single "real" photo online of this sub-assembly pan to confirm anything.
Old 01-25-14, 11:27 AM
  #289
e46m3lol
e46m3lol's Avatar
Just finished installing the o2 sensor spacers. New pair of turbos are also going on today.
Attached Thumbnails Boosting with the twins... is250 turbo build-image-173922896.jpg   Boosting with the twins... is250 turbo build-image-3971274607.jpg   Boosting with the twins... is250 turbo build-image-1196628856.jpg   Boosting with the twins... is250 turbo build-image-26229367.jpg   Boosting with the twins... is250 turbo build-image-900713750.jpg
Boosting with the twins... is250 turbo build-image-892761194.jpg   Boosting with the twins... is250 turbo build-image-1017970921.jpg   Boosting with the twins... is250 turbo build-image-2924731854.jpg
Old 01-25-14, 03:56 PM
  #290
Gville350
Gville350's Avatar
Looking good!
Old 01-25-14, 05:02 PM
  #291
villeds
villeds's Avatar
Looking good! Any plans to post some numbers anytime soon? Really wanna know what kinda numbers you're getting with this
Old 01-26-14, 09:30 AM
  #292
Gville350
Gville350's Avatar
I'd be curious to see with the new "larger" turbos where the powerband has moved. Smaller turbos will spool up more quickly, but will "run out of steam" on the top-end of the rpms. But larger turbos spool up later, but make power throughout all rpms. All about CFMs.
Old 01-26-14, 10:37 AM
  #293
e46m3lol
e46m3lol's Avatar
I'm happy to be boosting again! Just like before... The car feels way quicker than stock. I do notice there is slightly more lag compared to the smaller turbos but overall it feels awesome! I've been without boost for about a week and a half so I'll be letting the ECU relearn itself and hopefully I can get into the dyno by the end of the week.
The new oil pump made a huge difference. Instead if having to run a pusher and a puller pump, I'm just running a puller pump (sucks the oil oils of the return side back into the tank). It's nowhere near as loud as some vette and gto guys claimed it to be.
Old 01-26-14, 11:59 AM
  #294
e46m3lol
e46m3lol's Avatar
Drove the car around for about 75 miles so far and the car pulls and spools so much harder than with the small turbos. However... I did notice that my boost gauge is only showing max of 2 psi at WOT. I have a feeling that something is of here unless I need to adjust the tension on both internal wastegates. If this is how it feels with 2psi... I can't wait to see what it does with 7psi!!
Old 01-26-14, 06:01 PM
  #295
Gville350
Gville350's Avatar
^I forget, from where did you get the source for the boost gauge? On the intake manifold?
First check that the line for the boost gauge is good and tight. Then triple check all of the I/C piping; could be a boost leak. Have you upgraded to proper T-bolt clamps yet? Here's a simple DIY for finding a boost leak :
If you then confirm you're all tight, then move on to adjusting the WG actuator arms.
Old 01-26-14, 06:03 PM
  #296
heyarms
heyarms's Avatar
Boosting 2psi is like maybe 15whp, your butt dyno is very liberal. Haha. Good luck getting it to make it to the dyno soon.
Old 01-27-14, 09:06 AM
  #297
SH4DY
SH4DY's Avatar
^ This
You really need to get that thing to the dyno and get a wideband installed. Bigger turbo's = more airflow = leaner AFR's. Most internally gated turbo's come set at 6-8psi and I doubt you're losing 10+ psi through the piping and IC unless you've got a serious leak (it should be audible if it's that bad). Check back over your boost gauge connections and don't be afraid of using zip ties.
Also, do you have any in-car footage of the boost gauge and instrument cluster while driving under boost?
Old 01-27-14, 02:44 PM
  #298
e46m3lol
e46m3lol's Avatar
I was doing some research on rear mounted turbo setups and I read somewhere that for every foot of piping you lose about .6-.8 lbs of boost. If that is correct then 2 8lb internal wastegate turbos =16lbs - 13 ft of piping = 10.4lbs lost minus the pressure drop from the intercooler... 2 lbs doesn't seem to off at the intake manifold.
I don't hear any leaks. No CEL and everything sounds fine.
Made this video on my way to work this morning. 14:25 is really the only cool part worth watching. lol
I'll make a video of my gauges tonight on my way back home from work.
Old 01-27-14, 04:04 PM
  #299
po1qw
po1qw's Avatar
man that sound hella good
Old 01-27-14, 05:01 PM
  #300
Gville350
Gville350's Avatar
Have you noticed that you have smoke when you get on it from a stop light?
Quick Reply: Boosting with the twins... is250 turbo build
