Boosting with the twins... is250 turbo build
Old 12-15-13, 12:44 PM
  #31
e46m3lol
e46m3lol's Avatar
Thanks mike for the advice on the location of the MAF and bov. I gutted out the front bumper area where the intercooler will go. I'll see if there is a way to retrofit the brake ducts once the intercooler piping is installed.
In reference to the position of the vacuum line... I believe you're referring to the nipple that has a cover on it correct?
Attached Thumbnails Boosting with the twins... is250 turbo build-image-3648416600.jpg   Boosting with the twins... is250 turbo build-image-19888592.jpg   Boosting with the twins... is250 turbo build-image-989111998.jpg   Boosting with the twins... is250 turbo build-image-294340584.jpg
Old 12-15-13, 02:20 PM
  #32
mikellucci
mikellucci's Avatar
Yes! Use that nipple for a vacuum source. If you need an additional source then I'd suggest tapping a new one as shown above. Good deal
Old 12-15-13, 02:40 PM
  #33
e46m3lol
e46m3lol's Avatar
Just finished wiring up the switch that will automatically turn on the oil pump. I bought a universal radiator fan switch and instead of connecting the heat sensor, I rigged it so it'll always have power whenever the ignition is on. Came out really clean once I tucked all the wires in.
Attached Thumbnails Boosting with the twins... is250 turbo build-image-2333867073.jpg   Boosting with the twins... is250 turbo build-image-3531305130.jpg
Old 12-15-13, 03:03 PM
  #34
asuraIS250
asuraIS250's Avatar
Very interested in seeing the outcome of this build
Old 12-15-13, 04:44 PM
  #35
Gville350
Gville350's Avatar
So how exactly will you have the recirculating oil system for the turbo plumed? Is the pump pumping oil into the turbo from the reservoir or is it taking the oil from the oil return back into the reservoir? Will you not need a pump to reform each action?
Old 12-15-13, 08:26 PM
  #36
e46m3lol
e46m3lol's Avatar
My plan this whole time is that the pump will get oil from the reservoir, pump it down to the turbos and it'll recirculate by itself back into the reservoir. Now that you mention it though... It may be best to connect the pump to the oil return back into the reservoir. Once the turbos get installed I'll double check to make sure one pump is enough for both turbos, if not I'll have to run one oil pump per turbo.
Old 12-16-13, 07:10 AM
  #37
mikellucci
mikellucci's Avatar
Nice progress! You're not messing around!
Gravity will help get oil from your tank down to the first turbo. I would put your pump just after the 2nd turbo as it should pull oil thru and back to the tank.
One pump should be plenty with a separate oil system. Rotrex uses a little gear pump and it does a fine job of pulling oil ....any true external scavenge pump should be capable for your application.
Whatever works in real time though..you'll have to do some trial and error before you're up and running.
Old 12-16-13, 09:03 AM
  #38
e46m3lol
e46m3lol's Avatar
Mike... I don't mess around ha ha
I didn't know what to give myself for Christmas so this will be perfect.
I'll be dropping off my car off today after work and the fun will begin! Still reading up on what size piping to run. I see STS turbos uses 2.25" on their g35/350z setups. Any suggestions?
Old 12-16-13, 09:39 AM
  #39
e46m3lol
e46m3lol's Avatar
I was doing some more reading and I saw that a 350z owner posted that with 4 qts of oil his oil temp was about 165 degrees after about an hr of driving. I may have to purchase a bigger tank and also run an oil cooler.
Old 12-16-13, 12:16 PM
  #40
WylieKylie
WylieKylie's Avatar
^165 degrees is fine. In most engines ~200 degrees is steady state oil temperature.
Old 12-16-13, 05:00 PM
  #41
Gville350
Gville350's Avatar
Perhaps a remote-mounted oil cooler can be added to help with the turbo oil cooling? I pulled this up rather quick on ebay and it'll work, but perhaps too long? Anyhow, you get the idea.
http://www.ebay.com/itm/New-FRAM-TC6100-Universal-Transmission-Oil-Cooler-Kit-/360650782863?pt=Motors_Car_Truck_Parts_Accessories&hash=item53f876388f&vxp=mtr
Oh, add it'll be a good idea to run an in-line oil filter/screen before the turbos.
Old 12-16-13, 06:24 PM
  #42
e46m3lol
e46m3lol's Avatar
Thanks Gville! I didn't now oil coolers were that cheap.
Dropped the car off today after work and the guys started figuring out how to run the least amount of pipes with the least amount of bends. I'll check back tomorrow evening to snap some pics of whatever progress they've made.
Attached Thumbnails Boosting with the twins... is250 turbo build-image-3208899000.jpg   Boosting with the twins... is250 turbo build-image-2157485594.jpg
Old 12-16-13, 06:31 PM
  #43
Hoovey689
Hoovey689's Avatar
Where are the turbo's being mounted? In the engine bay or turbo-back like that IS-F was a few years ago?
Old 12-16-13, 06:52 PM
  #44
e46m3lol
e46m3lol's Avatar
There is no space to put the turbos up front so they'll be going in the back where the stock mufflers used to be. Just like this:
Attached Thumbnails Boosting with the twins... is250 turbo build-image-998717728.jpg   Boosting with the twins... is250 turbo build-image-3530457250.jpg
Old 12-16-13, 07:46 PM
  #45
sushiboi
sushiboi's Avatar
In for the progress!! Can't wait to see the finished product!!
Quick Reply: Boosting with the twins... is250 turbo build
