supercharging my is350
#136
As soon as PPE comes through with that exhaust I ordered...MAPECU3 will be next install
#137
Looks like my exhaust is being completed this week and just needs to be sent for coating...I already have next week scheduled for install and dyno time. I will post many pics of the exhaust and try to get some exhaust sound clips up.
#141
Here some pics of the exhaust (2.5" pipe) all I can say build quality was top notch, guys at the shop were impressed with the quality of the build and perfect fit of the exhaust, also everyone liked how it sounded couldn't be happier with PPE exhaust!!
#142
I had it on the dyno but results are incomplete at 4500 rpm boost dropped off for 4 psi to 1 psi next week going fix and maybe have some dyno results to post... but ill post what I got i hit 319 whp and 350 tq before boost dropped... Shop said it looked like car would put down 400 tq if boost didn't drop. I had some video to post of my car on the dyno but phone didn't save it ill post some next go on the dyno..
#143
Get an extra bung welded in for a wideband! Those "sniffer" exhaust readers are inaccurate.
Sounds like a typical boost-leak somewhere. Once you get that figured out, let us know what you ended up at "power-wise"!
#144
yea thinking it has to do with the bov need to change vacuum source and maybe play with springs
Here's the latest dyno run over lapped the previous dyno run right after I had PPE headers installed I had more boost before something is not right??
#145
That's quite the boost drop for a spring issue; sounds like a "major" boost leak. Are your pipes bead-rolled with T-bolt clamps? New components or used?
Where is your current vacuum source? I pulled my engine cover today and played around with this port on the intake manifold. Perhaps a good source? IDK.
#146
The pipes are not bead-rolled I have t-bolt clamps. From the pic you posted the area you circled is exactly where my vacuum line is currently routed to. I’m going tap a new vacuum port right after the throttle body as recommend by another member with more experience in supercharging the IS.
#147
Do the DIY hair-spray trick on the piping then; I've only ever used bead-rolled I/C piping...never had a boost leak. The one component that wasn't bead-rolled on my Honda (the TB) managed to pop off during dyno tuning; scared everyone, mostly me I guess. Enough pressure that the steel piping dented the shock tower! What a relief after such a simple fix though.
#149
