supercharging my is350
Old 02-25-14, 05:46 AM
heyarms
heyarms's Avatar
Excited for you. Boost really wakes up the car
What is the small air filter for? And your bracket looks powder coated? Nice touch if so.
Old 02-25-14, 09:46 AM
nikogio38
nikogio38's Avatar
Filter is for valve cover removing line that would run to the intake pipe. Yea I polished up the procharger and went with a flat black on the bracket and spacers. Only thing I want standing out is the shiny charger. I also put flat black on all the piping as well. Ill get more pics up of the finished product soon.
Old 02-25-14, 10:16 AM
xvector
xvector's Avatar
soooo jealous!
Old 02-25-14, 03:15 PM
nikogio38
nikogio38's Avatar
After the supercharger install what power mod do you think will produce the most power??? Other than my S/C the car will be stock.
Old 02-25-14, 03:20 PM
heyarms
heyarms's Avatar
I've always lived by the "work your way forward" approach with power. Meaning, start with exhaust, midpipe then headers then boost it. That way by time you're pushing more air through the system, it is able to breathe better. So throw headers and exhaust on. Your engine will appreciate it.
Old 02-25-14, 04:54 PM
smokyis350
smokyis350's Avatar
Subscribed for some dyno numbers. Hopefully you get a chance to dyno the car bone stock.
Headers will produce the most power other than nitrous. PPE headers, you are looking at around 10-15WHP. A full catback ~5-10WHP, intake ~5WHP.
Old 02-27-14, 07:22 PM
nikogio38
nikogio38's Avatar
Car was put on dyno today stock was 260hp to the wheels. Wasn't there when it was done..but when the procharger is installed I will post final dyno sheet. Also just purchased a set of long tube PPE headers today. When ever those get in ill get them install and run it on the dyno and see what kinda of numbers I get.
Old 03-02-14, 01:14 PM
freal
freal's Avatar
looking foreward to those increased dyno numbers!!!
Old 03-10-14, 04:42 PM
nikogio38
nikogio38's Avatar
All my parts i need to install is building up!!
Finally got my BC coilovers 14k/12k with extreme drop and swift springs!
Attached Thumbnails supercharging my is350-2014-03-07-16-32-47.jpg   supercharging my is350-2014-03-07-16-33-08.jpg
Old 03-10-14, 04:53 PM
nikogio38
nikogio38's Avatar
Got some final numbers from the supercharger install. Only got to drive the car from the shop to my home today... WOW the power is deffff noticeable!!! Base line I put down 260.5 hp and with only 3.5 psi the car put 299.8. I’m happy with it but I want more so today while I was at the shop I had them order a different size pulley so next time I post dyno it will be with from 2 to 3 psi more. Ill post the dyno with the new pulley size than another dyno run with the PPE headers installed.
My car is completely stock on the base line dyno...
Attached Thumbnails supercharging my is350-base.jpg   supercharging my is350-3.5-psi.jpg
Old 03-10-14, 04:54 PM
nikogio38
nikogio38's Avatar
O and all dyno runs were in 4th gear
Old 03-10-14, 04:58 PM
laobo979
laobo979's Avatar
Nice number but make sure it's also in snow mode accurate.
Old 03-10-14, 06:52 PM
mike33
mike33's Avatar
Nice nikogio38... 40 whp from 3.5 psi is not bad, looking forward to more dyno numbers with the new pulley and headers... Keep up the good work
Old 03-10-14, 08:30 PM
heyarms
heyarms's Avatar
Glad to hear you finally got the car out of the shop and put down some good numbers.
Snow mode won't make it more accurate, by the way, it'll just keep your car from wanting to downshift while on the dyno when you get it going.
What kind of dyno are you running on?
Old 03-10-14, 10:45 PM
nikogio38
nikogio38's Avatar
Hayarms I think on the top of the dyno sheet it says what type of dyno they ran it on. YOU WERE RIGHT THE CAR IS TOTALY DIFFERENT WITH ONLY 40HP... I’m hoping with the pulley install ill gain another 25HP and then with the PPE headers hopefully another 15HP!! Then after this is all done its time to put the IS on a diet!! IM SHOOTING FOR 200 POUNDS OFF!!
Quick Reply: supercharging my is350
