supercharging my is350
Old 03-17-14, 03:04 AM
  #46
nikogio38
nikogio38's Avatar
I have another video im trying to post it from 30-90mph....im having some problems with trying to upload but im going get it done soon
Old 03-20-14, 12:35 AM
  #47
nikogio38
nikogio38's Avatar
I installed my BC coilovers this week. I went with BC coilovers extreme drop 14k front 12k rear and swift springs. All I can say the ride is amazing way better than stock. This setup out performs the stock suspension in every way. I also weighed the stock suspension to the BC setup. Stock shocks/F sport springs 65.3 pounds VS. BC coilovers/swift springs 39.2 pounds a weight savings of 26 POUNDS!
Attached Thumbnails supercharging my is350-2014-03-19-11-39-25.jpg   supercharging my is350-2014-03-19-11-39-42.jpg   supercharging my is350-2014-03-19-11-40-04.jpg
Old 03-24-14, 08:24 AM
  #48
nikogio38
nikogio38's Avatar
Heres a 0-75 pull. traction control was on and just lowered my car so camber is off not getting good traction and it was a bumpy road. ignore the nose in the background.
Old 03-24-14, 01:59 PM
  #49
Mokey
Mokey's Avatar
Originally Posted by nikogio38
heres a link on youtube i posted from 0-80mphs. Forgot to turn my dash lights all the way up so its dark. http://www.youtube.com/watch?v=32crQpzdGZQ
Looks like it hits 60 in the 5s, so with a supercharger it just saves some milliseconds from stock
Old 03-24-14, 02:30 PM
  #50
nikogio38
nikogio38's Avatar
I couldn’t say milli-secs it definitely fees a lot faster. Besides I couldn’t tell you what my 0-60 was before with traction control on. I plan on ordering a GTECH meter and see what it says. And being that it is a belt driven supercharger there is that loss of power down low so seeing a difference in launch might not be so big, but from my experience so far I see a huge difference when I’m from a rolling start 25 to 35 mph range it pulls a lot harder up to 100mph!!! It’s very hard to stopwatch the video!!!! And both videos were done after the car was S/C....
Old 03-24-14, 03:43 PM
  #51
heyarms
heyarms's Avatar
Lol funny video with the person screaming
Yeah pulls from a roll are definitely where it's at for me too, altho it's boosted 250! My butt dyno still says meth injection was a solid purchase too haha
Old 03-26-14, 09:13 AM
  #52
nikogio38
nikogio38's Avatar
What meth kit did you go with? Where did you mount yours?
Old 03-26-14, 09:18 AM
  #53
nikogio38
nikogio38's Avatar
Here’s a pic of the engine bay for all you none believers... haha. Ignore the cheap filter I got a K/N waiting for install but first I’m going to relocate the filter where the intake pipe runs the filter will be located on the other side of the inlet pipe that runs to the throttle body.
Attached Thumbnails supercharging my is350-2014-03-15-12-19-50.jpg   supercharging my is350-2014-03-15-12-18-52.jpg
Old 03-26-14, 09:41 AM
  #54
nikogio38
nikogio38's Avatar
I had an idea of how to setup the filter but don’t know if it would be worth the extra hassle to set it up this way. I was thinking about put a larger filter opening and filter area. Would if get more air in?? I would weld a larger pipe on to the original size pipe and increase the size to a 5 inch pipe. I put a quick drawing together to get my idea across. Now I need input if this would help performance at all???
Old 03-26-14, 09:54 AM
  #55
FSportIS
FSportIS's Avatar
I think current set up already have enough air flow. What might help is locate the filter near the area where you can get colder air and that would help more. Please clean that filter which will definitely help lol, no pun intended.
Old 03-26-14, 09:59 AM
  #56
heyarms
heyarms's Avatar
I'm using Snow Performance Stage 2 meth kit. It's boost controlled and a progressive spray, so it's controlled by a module where you set the Boost level where it starts (I have it set around 3psi) and where your max boost is (7.5psi). So it ramps up the spray from minimal to 100% spray between 3 and 7.5psi. I trunk mounted it so you have to buy an additional $50 check valve to allow it. Simple install too.
Old 03-26-14, 10:40 AM
  #57
nikogio38
nikogio38's Avatar
Thanks for info. Is the pump very load when it turns on? Did you ever run your car on 7+psi before you installed the water meth??
Old 03-26-14, 10:43 AM
  #58
nikogio38
nikogio38's Avatar
That’s my plan to relocate where it would get cooler air and I could then install the snorkel back in the car to get some cool air in the engine bay.
Old 03-26-14, 02:38 PM
  #59
heyarms
heyarms's Avatar
It's very quiet. You won't hear it, even if it was installed in the cabin you would only hear a click basically when it comes on/off.
I ran 7.5psi for almost 20k miles before installing the methanol, and I live in hot and humid Houston Texas.
Pic of it in trunk
Old 03-26-14, 03:58 PM
  #60
FSportIS
FSportIS's Avatar
Yeah i see the picture, that is probably a better location since it is further away from the hot engine. There could still be a problem though because air still comes in from front grill and move through the hot engine before getting to that filter. I think somewhere near the front grill but further away from the hot engine would be good.
Quick Reply: supercharging my is350
