Making Custom Air Box- Lexus IS 350
Old 02-25-14 | 01:04 PM
zxratd's Avatar
zxratd
Lightbulb Making Custom Air Box- Lexus IS 350
I want to make an LFA style air box for my is350 with velocity stacks. I have some ideas from the inside a guitar for the sound. My question is does anybody know the size of the intake ports to the lower intake manifold in millimeters?
thanks,
Brian
email: crowell.brian809@gmail.com
Old 02-25-14 | 01:19 PM
Gville350's Avatar
Gville350
Very curious to see where this goes! Not too many folks will have a lower intake manifold just sitting around where they'd be able to pull those #s, but you can get lucky.
Old 02-25-14 | 10:11 PM
WylieKylie's Avatar
WylieKylie
Velocity stacks can increase the volumetric efficiency of the engine, but changing the length of the intake runners also changes how the wave tuning in the intake tract works. The variable valve timing also plays into this. Chances are it won't make a huge difference one way or the other, but there is the chance that you will create a "dead" spot somewhere in the RPM band. I'm assuming you plan on using the stock upper intake manifold and TB? I'm not sure how much space you have in the plenum, but I would still suggest using the shortest velocity stacks you can find, and while you are in ther spend some time porting the runners as well. Also the filter and intake before the TB have a much greater effect on sound than the manifold so I wouldn't expect any change in sound.
Old 02-26-14 | 02:11 PM
Gville350's Avatar
Gville350
Perhaps something like this?
https://www.clublexus.com/forums/per...m-in-love.html
Old 02-26-14 | 02:27 PM
06350F's Avatar
06350F
I always wanted to take a veloicty stack and put it where the opening goes on the F-sport lower air box.
Old 03-01-14 | 03:19 PM
zxratd's Avatar
zxratd
I'm going to keep the stock lower and build a custom upper..
Old 03-03-14 | 03:55 PM
WylieKylie's Avatar
WylieKylie
That is going to be a big project. I'd take some inspiration from the IS F intake manifold rather than the LFA. The LFA has individual TBs inside a common plenum, the IS F has some great velocity stacks cast inside the plenum and a single TB:
Old 03-03-14 | 04:00 PM
FSportIS's Avatar
FSportIS
Wow. This is new and interesting. Subscribed. I look forward hearing more. Keep it up.
Old 03-08-14 | 10:40 AM
zxratd's Avatar
zxratd
I'm adding some other sound tuning stuff in the enclosed air box. I will keep the original design..
Old 03-08-14 | 12:05 PM
jbernal220's Avatar
jbernal220
looks awesome! keep the good work
mjn88
RC F (2015-present)
15
09-19-18 04:52 AM
mrayes
Performance
12-22-08 10:56 PM
miniround
RX - 1st Gen (1999-2003)
02-28-07 09:52 AM
FILIPE
Performance
08-31-02 01:17 PM
RacingAristo
01-24-02 06:14 PM
