F sport exhaust left hanging low?!
Just a question for you guys with the fsport exhaust, I recently installed it on my car and for some reason the left side is hanging lower than that right side.., and it seems to stick out a bit more than the right side. Just wanted to see if its normal or if i installed it wrong
It is normal fitment issue. My F Sport exhaust is like that but it is not really noticeable unless you look at them closely.
Beside, if you listen to the sound, the right side is louder than the left one because the right side is a dummy muffler with straight through pipe while the left one is a real muffler. I think they design it on purpose to fine tune the sound and yeah I love the sound so much.
You should be able to fix the alignment but it may need a second set of hands. I had the same issue on another car with dual exhaust. You need to disconnect the piping and have someone push or pull on one side while you bolt it on. Otherwise you may be able to get a different rubber mount. And if your super **** then go to a muffler shop to re-weld the mount.
On my F-Sport exhaust the left side pointed up a little more than the right. I loosened the bolts at the muffler/Ypipe and put my floor jack under where the muffler mounts to the Y pipe and jacked it up till the pipe was pointed like the other side than tightened the bolts again. It looks even now.
Ain't no pursuit of perfection
Also asked the dealer to adjust it but apparently its normal, saw the same on another customer's IS.
The second picture is exaggerated imo since it does not look as bad as that in person ......
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
Did you guys use the 2 rubber exhaust grommets that come with the F Sport?
They go on the inner hanger on each of the muffer cans if that makes sense. They are MUCH stiffer than stock and also a little shorter to pull the exhaust closer to the bumper. This solves the hanging issue and the side to side shaking issue. However one side will still stick out more than the other.
Yeah i agree with you. There is still some little shaking under heavy acceleration though.
Yeah the left one stick out more than the right one. However, it doesn't look bad. I like to see the "F Sport" engaved text there when I walk by![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
