2jzgte TPS Issues
2jzgte TPS Issues
Going down the road, if I go WOT, the throttle percentage readings on the safc goes to 100% then falls back down. Sometimes to as low as 30%. Is it a bad tps, miss adjusted one, or something else entirely?
As it comes into boost, voltage drops dramatically at the tps. Doesn't seem to do it under no load, and the voltage sweep is good without the car running.
