Really Loud M2!!! Why?
I just got my M2 Performance Exhaust put on and it is insanely loud... After reading reviews and all i thought there would be no drone and it would be pretty quiet, just a deeper sound. Anywhoo.. installed it, and it is very loud, and there is a ton of drone between 1700 and 3400 RPM. I do have a resonator delete, and an x-pipe, so maybe thats why its so loud.
My question is... is there any of you that had the m2 with a resonator, and then got the resonator taken out? Did it have drone before and/or after the resonator delete? and did your guys' M2 mufflers just look like a perforated pipe going through the muffler to the tips.
Your drone is caused by the invidia midpipe you most likely have.
My setup: Cats up at the headers, cats in the middle, xpipe into the mufflers, i shall post a pic.
I want to keep it true dual, so would i have to buy two resonators?
(Im not familiar with the term midpipe.. i assumed it was a pipe that took out the two cats... or is it the pipe that takes out the resonator?)
So this was my setup after the resonator delte, only thing now is the mufflers are M2's instead of the stock ones. Same dual piping same x-pipe location etc..
This should be an improvement from stock and should give you much less drone. Hope this helps!
Bringing this back up!
So I went the cheap way and had my muffler guy throw on two cheapy torpedo resonators... Still have a **** ton of rasp, and basically the same drone. Im guessing this is because i got what i paid for... So now i'm looking to do it the right way.. Gonna purchase two of the Magnaflow resonators Flattire posted above i think. (unless anyone has other input)
Also, should I buy two and keep it true dual?? or should I go back to factory set up and only buy one Magnaflow?
I want as much performance out of it as i can get, but i want it to sound nice. If there's not really a noticeable difference between true dual and a Y-Pipe then i guess i can just do that.. I was under the impression I got more gains from the true dual.
^^True dual will net more HP. I had a custom 2.25 inch y piped exhaust and it was a improvement over the stock one. I decided to do a true dual x pipe and THAT made the most difference. I felt instant torque as soon as I installed it on but I also changed the piping size to 2.5 inch.
Fire Slayer
