GS400/SC400 engine difference
Actually, in 98 the 1UZ-FE (4.0 V8) is almost identical in the GS400, SC400 and LS400. The GS400 has a better exhaust system and therefore has 10hp/10tq advantage. The differences between 90-97 engines and the 98-2000 engines are many including ecu controlled variable valve timing and variable area intake manifolds and higher flow exhaust manifolds. All 98+ engines have the throttle body at the front of the intake. Do a search under my name and you will find many posts on these subjects.
