Direct fit y-pipe..Magnaflow 24321?
Old 05-06-14, 11:09 AM
kphu
kphu's Avatar
I took my car to a custom exhaust shop today, they fabricated a custom y-pipe in about an hour for $370 installed including tax. Not bad considering the magnaflow would have costed me $380 + install. They recommended to take the cat out at the end since no sensor after that so i went with it.
Old 05-07-14, 08:50 AM
Sampak
Sampak's Avatar
Hmm, mandrel or crush bends?
Old 05-07-14, 06:19 PM
kphu
kphu's Avatar
I don't know what mandrel means but the machine they had kepted the tube perfectly round during the bend so I'm assuming Mandrel as oppose to crush.
Old 05-08-14, 04:56 AM
tmf2004
5% Club. Killing it!!!
tmf2004's Avatar
thats a muffler not a convertor... looks good though
Old 05-10-14, 09:27 PM
yada
yada's Avatar
Do you guys get new cats as well as the pipe?
Old 05-11-14, 02:56 AM
NorthStyle
NorthStyle's Avatar
Are you asking if they come with the pipe? ...or are you asking if people purchase them separately, with the pipe?
Old 05-11-14, 11:14 AM
yada
yada's Avatar
Separately changing the cats
Old 05-11-14, 02:48 PM
NorthStyle
NorthStyle's Avatar
Ahhh... gotcha. Well, when I purchased my replacement pipe I just went ahead and ordered new cats since I'll be changing out the entire exhaust from the headers back. I figured I might as well since the car is closing in on 140K miles.
Old 05-11-14, 04:21 PM
RoMiLex
RoMiLex's Avatar
Never understood why it went down to one just to split back out to 2 again. Supporting 300hp seems like you'd want true duals all the way with either a X-pipe, H-pipe or a 2 in 2 out muffler/resonator to equalize the pressure..
Old 05-12-14, 09:54 AM
Sampak
Sampak's Avatar
Ah, ok that's a great deal then! Crush bent piping is usually cheaper for you and the shop I believe (e.g. 2.5" pipe gets bent by "crushing" the inside area and often leads to almost 0.25" to 0.5" of lost diameter).
Mandrel bends are done on a much, much larger mandrel $$$ machine (from work done on one of my previous cars) and using a different method and makes the pipes keep their diameter around the bends, but can be limiting when dealing with tight, close together bends.
Old 08-06-14, 03:21 PM
firelizard
firelizard's Avatar
I ordered the Magnaflow direct-fit and the correct part number arrived but it was a few inches too short, the way people described SC430 Y-pipes. I got on the horn with Magnaflow and they confirmed that the SC and GS part numbers were the same in their catalogue as well as AllPart (their OEM part catalogue). I had the exhaust shop extend the mid-pip to meet the Magnaflow piece and sent pictures of the process to Magnaflow. I'll update when I hear back from them.
Old 08-06-14, 07:02 PM
NorthStyle
NorthStyle's Avatar
Sucks to hear that it didn't fit but I tried to warn you guys that the SC430 and GS430 y-pipes aren't compatible. As for Magnaflow, they should've checked harder as the part numbers between the two are different as well: SC430 (1741050340) and GS430 (1741050330)... They shouldn't be advertising this product as cross compatible.
Old 02-15-15, 12:30 AM
SweetS160
SweetS160's Avatar
I ended up adding a flex section to extend the pipe
Old 02-15-15, 12:08 PM
rwheelz
rwheelz's Avatar
Just ordered a Megan Y-pipe for SC430 and will be adding the extension to fit it onto my GS400.
Old 02-15-15, 04:10 PM
SweetS160
SweetS160's Avatar
Post some pics when you get it put in
Quick Reply: Direct fit y-pipe..Magnaflow 24321?
