desperate need of help code 24 & 31 aristo swap
2jzgte vvti swap ina 2nd gen gs I'm getting a code 24 and code 31 iat and maf codes I can't for the life of me find the iat sensor anywhere I've read that it's on the fuel rail but I don't see a spot for it anywhere.. any help as far as pics of it I've searched and can't find anything...
The problem I'm having is when I start the car without the maf plugged in I can't throttle it without the car dying.. as soon I plug the maf in it dies as well
i have 2 mafs that i tried and both do the same thing when they are plugged in the car just dies.
when its unplugged as soon as you hit the gas the car acts as if it chokes out and dies. cant start the car with the maf plugged in either.
i thought that if the maf is bad that the car would be in limp mode and i just couldnt rev past 3k which leads me to believe that something else may be the culprit
in desperate need of help if anyone can
thank you
thank you
