Oil
Old 05-22-14, 12:44 AM
blooch253
blooch253's Avatar
Default Oil
What kind of oil are you using on your ISX50?
Old 05-22-14, 07:32 AM
alexs350
alexs350's Avatar
I use Mobil 1.
Old 05-22-14, 10:33 AM
UniSlayEX
UniSlayEX's Avatar
I use the OEM Genuine Toyota Motor Oil but you're good with anything 5W-30, 0W-20
Old 05-22-14, 10:41 AM
reyoasian
reyoasian's Avatar
^ Lol "Genuine" Toyota Motor Oil
Old 05-22-14, 11:44 AM
massaker
massaker's Avatar
Mobil 1 no carbon build up yet. not sure if that helps or not but no problems either
Old 05-22-14, 02:28 PM
knguyenk
knguyenk's Avatar
I used to use 5W-30 Mobil 1 with no problems. I recently changed to 5W-30 Lubro/Liqui Moly and haven't looked back, made in Germany and easy found at NAPA Auto Parts.
Old 06-05-14, 12:15 AM
blooch253
blooch253's Avatar
Gonna try out the Royal Purple HPS. Anyone had any experience with it?
Old 06-05-14, 08:19 AM
idoke1
idoke1's Avatar
^^royal purple is fine. I used it before. At the moment, I'm using penzoil fully synthetic.
Old 06-05-14, 10:33 AM
UniSlayEX
UniSlayEX's Avatar
bob4256 swears by it. Check his build thread.
Old 06-05-14, 12:58 PM
Gville350
Gville350's Avatar
Though Walmart has Royal Purple on the shelf now right next to the Mobil 1 full syn I use, I still couldn't see myself spending the extra $10 for something that (to me) works the same. I've got an oil change coming up this weekend myself; looking forward to treating my Mistress to some fresh fluids.
Old 06-05-14, 02:10 PM
liqB
liqB's Avatar
I started with Mobil 1(5w30), but I would lose about a quart every 3k miles so I switched to Amsoil(5w20 then 5w30) was still burning oil. Finally decided to try Castro Edge and my oil consumption seemed to have been reduced significantly.
Old 06-05-14, 08:28 PM
Gville350
Gville350's Avatar
^For older or worn engines that burn oil, it might actually be better to run dino oil. The slicker full syn oils might be sneaking past piston rings or valve stem seals causing smoke or oil loss.
Ohoopee
IS - 1st Gen (2001-2005)
03-28-22 11:28 AM
Eolafan
ES - 6th Gen (2013-2018)
12-26-15 03:30 PM
rftuck
RX - 3rd Gen (2010-2015)
29
01-25-11 10:37 AM
Rollin'ES3
45
08-09-08 01:53 PM
Quick Reply: Oil
