Question on going w/ a single turbo on GS300
Im a little frustrated on the limitations of force feeding my GS400. I just cant swing 35 grand on the TT set up, and the superchargers seem to be limited to the RMM set up. Im thinking about selling my GS400 and buying a GS300 to put a single turbo kit on it(then swap all of my other goodies over to the 300). If im not mistaken isnt the GS300 engine the same as the non turbo Supra? I used to be deep into the Supra world, so I know there are a ton of options for going single turbo on that engine platform. Has anyone here gone that route, or does anyone have any input on the subject for me.
I need to be force fed!!
![Mad](https://www.clublexus.com/forums/images/smilies/mad.gif)
if you're thinkin JZS161 ARISTO.. most of the swaps with the VVT-i 2JZ-GTE disconnect the system and run it as a regular motor.. kinda defeats the purpose to me.. run as a regular motor you're free to do all the mods for power you want tho.
For older JZS147 ARISTO you're forced to go single due to the firewall..
I had choice of buying a 2000 gs400 in blue with nav and hid or buying a 2000gs 300 in blue without nav or hid but the car was in mint condition. Since I am addicted to boost and I know there is no way in hell my girl will allow me to pay 30k + on a turbo kit my choice became easier. Gs300 all the way, right now the car is slow as hell compared to the cars that I am used to driving but its ok, by next year all of that will change. Honestly a Gs400 is a great car with good performance If I already had a Gs400 I don't think I would sell it to buy a GS300. Keep the Gs400 and if you can afford it buy a corvette or used mkiv supra that will take care of your need for speed if you can afford it.
And to answer your question yes supra n/a and the gs300 have the same motor. If you go on supraforums.com, go in the natural aspirated section and look for DaveH he has a 600+hp NA-T supra that runs 10 seconds on a automatic transmission. Basicly all a GS300 or a n/a supra needs is a thicker head gasket and arp head stud and bigger injectors and we should be good for 500+hp.
Later"Jose
I almost forgot after 350 to 400rwhp you will need tranny work. Valvebody and T/C will be good but eventually with more power you will have to get a built tranny.
Later"Jose
Does the NA supra also have VVTI?
SRT has a turbo kit ready for you and I am sure that sound performance can cook something up for you (have you seen ebanks SC with a 2JZ-GE, 981rwhp).
but it seem most of the high power 2jz-ge don't have them or they disable it.
Later:Jose
Later:Jose
Thats why I opted to buy the gs300. I figure I make the wife happy and buy something with comfort and luxury and still able to run some 12 second passes on the weekends. So far I am pleased with the car, actually its better than I expected.
Later:Jose
I ended up selling them to go to the GS to meet my wife somewhere in the middle.
Later:Jose
VVT-i came out on 2JZ-GTE's in the newer ARISTO's (160/1)
older ARISTO's came with the 2JZGTE/GE (No VVT-i) and a 4.0L V8
Turbocharging a 2JZ-GTE w/ VVT-i the VVT-I is usually disconnected because most engine management systems cannot handle the complexity of the system. much simpler to just run the 2JZ as a standard motor.
anything and everything is possible but... a phrase i like to remember
KISS - Keep It Simple Stupid
You probably be able to use your Block with high compression.. but the head and intake manifold will most likely have to be changed for simplicity.
I have been doing some math on potential Lexus turbo systems.
The V8 would look something like this:
Manifolds: $1500 ($750 x 2)
Turbos: $2500 ($1250 x 2)
Intercooling: $1000
Fuel/Timing: $1500 (injectors and computer and tuning)
Exhaust: $1500 (full stainless system)
Misc: $1500 (hardware, gaskets, fittings, clamps, etc)
For a total of: $9500
This does NOT include engine upgrades or transmission mods. This would limit the max power to about 400rwhp. With mods to the engine and tranny 700-1000rwhp is resonable depending on turbos selected.
The I6 would look something like this:
Manifold: $750
Turbos: $1250
Intercooling: $1000
For a total of: $7500
As with the V8 this does NOT include engine upgrades or transmission mods. This would limit the max power to about 400rwhp. With mods to the engine and tranny 700-1000rwhp is resonable depending on turbo selected. With the I6 there would be less torque and a peakier engine but very fast whichever engine used. Turbos move air, as long as the engine they are attached to can harness their output... you are only limited by the turbos capacity and of course you can get BIG turbos
Intercooling: $1000
Manifold: $750
Turbos: $1250
Intercooling: $1000
![Cool](https://www.clublexus.com/forums/images/smilies/cool.gif)
now THAT is over simplifying things a bit
granted doin a layout for a V8 twin turbo will cost more doin a 2JZ-GTE swap...
but a stock twin turbo 2JZ-GTE with proper intercooling, cooling system, tuning... will already crack 400hp+ to the wheels
i'd like to see a properly cooled & intercooled twin turbo QuadCam V8 inside a Toyota
most impressive is how it'll all be packaged
Response in a turbo car is linked more to overall efficiency than engine layout
in either case the path to "excessive power to weight ratio" is much simpler & cheaper for the thread starter seeking more power from his GS by going the 2JZ-GTE route
downloaded some clips from kaaza and i was totally in trance by the sounds of turbo spoof and blow-off valve!! got a severeal questions about considering tubro charge my gs300...
1) when i mention turbo charging the gs, ppl ask me, "to stage one or to stage two?"
my question is how many hp is each number of stage?
2)what's the cost if i want to boost the car to 300-400 hp? do i need to have the automatic transmission reworked as well? can i still get the blow-off sound??
3)i live in south. cali. , any recommanded stores taht would provide durable turbo upgrade? bc i still need my gs to be the daily beater for at least another 3, 4 years.....
thanx a lot guys.
i like this robot cop smilie
thanx a lot guys.
![Cyclops](https://www.clublexus.com/forums/images/smilies/cylonA.gif)
alloys999
10-26-11 10:08 AM
