Reducing Throttle Body Heat
Old 03-17-03, 04:19 AM
skier1
skier1's Avatar
BananaGS, I found in my junk box a brass reducer fitting. The small side fit the hose coming from behind the throttle body and the larger sidefit the hose that is in front of the housing. I use some screw type hose clamps and WALLA! no leaks. Worked great.
Old 03-17-03, 05:20 AM
tomtnc
tomtnc's Avatar
Would someone that did this modification please post the size of the coolant inlet and outlet (to and from throttle body) hoses? I'd like to pick up the correct "reducer" fitting at the hardware store this week so I can do the mod this weekend.
Old 03-17-03, 06:14 AM
BananaGS
Tech Guru
BananaGS's Avatar
didn't I just post the size of the hoses in my last post?
Notes: for those that from the North section of the US, if you get 32F more than 1 day at a time, this is NOT for you.
Old 03-17-03, 06:21 AM
tomtnc
tomtnc's Avatar
Originally posted by BananaGS
[didn't I just posted the size of the hoses in my last post?
Sorry, I missed that part at the bottom of your post. 3/8" to 5/8" it is then
Also going to try your super-bright alarm LED install this weekend.
Keep up all the good work on those DIY's!!!! Great job.
scblackout
Performance & Maintenance
04-02-16 11:43 AM
DIM
IS F (2008-2014)
04-03-12 09:33 PM
NEbiker10
03-22-11 09:54 PM
98blkgs400
12-22-10 02:21 AM
FinanceGuy
01-15-07 05:29 PM
Quick Reply: Reducing Throttle Body Heat
