POP Quiz Hot Shot
Old 03-12-03, 07:56 PM
kodai
kodai's Avatar
Default POP Quiz Hot Shot
I would like to see just how many real performance guys are here. Please tell if you know what this is and how does it work. Do not worry, you are not being graded. haha Good Luck.
The vehicle is a 2001 GS 430.
kodai is offline
Old 03-12-03, 08:02 PM
tomtnc
tomtnc's Avatar
My first guess? I've seen oil filter relocations / auxiliary filter units similar to this (most due to turbo piping interference and / or filtration issues).
My second guess? It's a transverse mounted torque induced genuine calf-skin bi-valve actuator.
tomtnc is offline
Old 03-12-03, 09:54 PM
GlobeCLK
GlobeCLK's Avatar
looks like oil filter relocation kit.
GlobeCLK is offline
Old 03-12-03, 09:58 PM
BananaGS
Tech Guru
BananaGS's Avatar
oil relocation kit for those you don't want to get under the car to change the oil filter, the problem is you still have to get under the car to open the oil drain nut ha ha ha. save a bit of time with this. Look like a very clean install who makes the oil adapter? I like I like
BananaGS is offline
Old 03-13-03, 08:11 AM
kodai
kodai's Avatar
Correct to all,
It is a relocation kit for an oil filter. You all would be shocked in how many people asked me what it was at show i did a few weeks ago. This oil filter kit is designed for the Supra twin turbo but with longer lines it can be installed on the GS's. The other thing that needs to be done is to make a bracket. Hope you like....
Hope to see more Lexus guys and Girls at the up coming Import Revolution at Anaheim Ca. March 22.
Kodai
kodai is offline
Old 03-13-03, 11:42 PM
GlobeCLK
GlobeCLK's Avatar
my bro's company will debut on that show so I'll be there to watch.
GlobeCLK is offline
Old 03-14-03, 03:02 AM
tzu911
tzu911's Avatar
Thumbs up
cooos, which compaany is that
tzu911 is offline
Old 03-14-03, 11:26 PM
98GS4_STL
98GS4_STL's Avatar
Default one quick question:
what keeps oil from getting all over your sparkling clean engine bay?
( besides lots of rags : )
98GS4_STL is offline
Old 03-25-03, 07:47 AM
kodai
kodai's Avatar
Default Re: one quick question:
Gravity. Once you open the drain pulg and the the oil is mostly out, you can take of the oil filter off. Very little if any oil drips out. I still use a rag just in case some oil is still left over. Other then that is is very clean oil change....
kodai is offline
Old 03-25-03, 10:56 AM
aristo400
aristo400's Avatar
Refill on Blinker Fluid??
aristo400 is offline
Old 03-25-03, 12:10 PM
skier1
skier1's Avatar
That's the new hydraulic engine oil level stabilizer! It keeps a constant level of oil in the oil pan when you are cornering hard so the engine doesn't starve for oil! Hee hee. I guess a windage tray could do the same thing.
skier1 is offline
Old 03-30-03, 05:10 PM
JZS14SEVEN
JZS14SEVEN's Avatar
Default ha
don't you just love buyin IMPORTED "Earl's" lines and fittin's from Trust, Japan
dolla ballr billz
and everybody wonders why a "oil cooler and filter relocator KIT" cost so much
its cause you get like $200 in line and fittings
JZS14SEVEN is offline
Old 03-30-03, 07:03 PM
kodai
kodai's Avatar
Default Re: ha
dolla ballr billz
The relocation kit retails for $160. The whole kit not just the lines. Education should be key in all post. do you home work......
kodai is offline
Old 04-01-03, 02:01 PM
JZS14SEVEN
JZS14SEVEN's Avatar
Default Eduaction?? Go Learn to read
a Car Show Queen is tryin to tell me to do more research?
gotta love the import scene in America... its so ignorant...
and No, i don't.. HOMEWORK, do you work at home???
yada yada yada, the "oil filter relocation Kit" is relatively cheap.
but a "16row Trust oil cooler AND filter relocator kit" is not.
neither is the Retail on the EARL's braided lines & fitting that come with it...
feel like i'm repeating myself.. blah..
damn prissy lexus owners
Old 04-01-03, 05:28 PM
kodai
kodai's Avatar
Default Re: Eduaction?? Go Learn to read
Yes, i am telling you to do more research. Show car, yes. Daily driver yes. Clean car yes. Here are some number from the TRust master goods catalog.
16 row oil cooler (just the cooler) $490
Oil block adapt (to the block) $120
Thermostat $120
oil filter adat. $120
total $850
hardware makes up for only $40 of the retail price. This includes all brackets and lines and all other nuts and bolts. Yes, do more Research!!
By the way, what shop do you work for again?
kodai is offline
Quick Reply: POP Quiz Hot Shot
