F Sport drop in air filter... or the alike...
Old 02-29-16, 06:38 PM
  #31
asiandavid
asiandavid's Avatar
Any inputs?
Old 03-02-16, 12:01 PM
  #32
LexSense
LexSense's Avatar
Originally Posted by asiandavid
It doesnt close completely is that normal
Another pic with it not fully closed
I have my stock intake with the f-sport filter sitting in a box, so I took it out to check and yeah pretty much similar gap you are seeing.
I also took out the f-sport filter element and just tried closing the stock box without a filter and yeah pretty similar gap still - perhaps a minuscule amount less gap, but yeah in other words I believe it's just the structure of the stock intake box, and you have a perfectly normal setup.
Old 03-10-16, 05:25 PM
  #33
harkirath
harkirath's Avatar
I talked to the people over at L parts world and they said the F Sport Filter is a little bit bigger than the normal filter. They mentioned the F Sport cover is a little bit larger to accommodate the difference in filter size.
Is this valid or was the individual trying to sell me on getting the whole kit?
Old 03-10-16, 08:01 PM
  #34
Fsportme
Fsportme's Avatar
I just ordered the F-sport air filter only for the stock air box. Even if it's slightly bigger it should still fit properly with a little coaxing.
Old 03-24-16, 05:47 PM
  #35
Fsportme
Fsportme's Avatar
Update: F-Sport air filter is a direct drop in for the stock non-F airbox and no air gaps or clearance issues.
Old 03-17-17, 09:36 AM
  #36
Gtti
Gtti's Avatar
Does F sports filter fits Is200T?
Old 03-18-17, 09:25 AM
  #37
Solara350
Solara350's Avatar
can anyone post video sound of "Drop in Air filter" using stock intake box and tube ? do they make bigger sound than stock air filter ? i like to have that sound like whole intake kits but i'm lazy to do the installation, i just wanna drop in just the K&N or Fsport air filter not sure if they gives good noise like the full kit.
Old 03-18-17, 06:11 PM
  #38
gianttama
gianttama's Avatar
Is the f sport filter washable/reusable like k&n? Have a 16 350 awd non f, thinking to get the f sport filter or the KN? Can anyone tell what the real difference between the 2?
Old 03-18-17, 06:18 PM
  #39
Larry96815
Larry96815's Avatar
K & N filter is oiled, F sport filter is not.
Old 03-19-17, 10:31 PM
  #40
Rudiculous
Rudiculous's Avatar
No sound difference
Old 03-21-17, 01:55 AM
  #41
evltwn
evltwn's Avatar
I purchased the FSport filter and dropped it into my stock airbox. I did have a little gap issue others have stated and shown. As long as you can get the clips on and in place you'll be fine. I even went a step further and cut out a hole like the FSport box has in the lower front to get that extra air. Also I purchased an HPS intake tube from eBay. What I like about the HPS intake is it allows you to still install the sound resonator that the sock intake tube has. I am on my 1st full tank of gas with this setup, so I can't report any mpg differences yet. So I have the stock airbox with the FSport filter and HPS intake. Saved about $100 doing this vs buying a full FSport intake.
Old 03-22-17, 02:10 PM
  #42
gianttama
gianttama's Avatar
so i can just swap the tube w/ the stock one? i have 16 350 awd non f. or does it have to be the f sport trim?
Old 03-22-17, 06:10 PM
  #43
evltwn
evltwn's Avatar
They do sell the HPS intake pipe for non-FSport cars. Do a quick search on ebay, and you'll find them. Very easy to install too.
Old 03-25-17, 08:18 AM
  #44
Solara350
Solara350's Avatar
Originally Posted by Rudiculous
No sound difference
Thank you, what about if we buy the whole F-sport kit ? same sound to stock still ?
Old 04-19-17, 07:16 AM
  #45
mastalex
mastalex's Avatar
How do you like it? Any noticeable increase in power? Any change to the way it sounds?
Quick Reply: F Sport drop in air filter... or the alike...
