Drive Shaft Loop for IS2Gen
Just finished installing a Nitrous Express kit on my IS and palm beach international motor speedway requires a drive shaft loop installed in order to run the quarter. Has anyone installed a drive shaft loop for their IS2gen? I just recently ordered a universal drive shaft loop and i am curious what position along the drive shaft they have installed it.
I'll repeat some of this
The rules require that the loop is mounted within 6 inches of the front U-joint on the driveshaft for support of the driveshaft in the event of a U-joint failure. The loop must enclose the driveshaft in a full 360 degrees and must be either 1/4-inch thick and 2-inches wide or 7/8-inch x 0.065-inch welded steel tubing.
