Gas Mileage - Eco Vs. Sport Mode
Old 06-01-15, 09:30 AM
JGDrew
JGDrew's Avatar
Default Gas Mileage - Eco Vs. Sport Mode
Hey guys,
I bought a 2014 IS 350 in late January. For the most part I have driven it around the city in eco mode. However, Sport mode is a lot more fun. I've been digging around the internet trying to figure out just how much better gas mileage is in eco compared to Sport mode. Does anyone know the number on this or now how effective eco mode really is? Becuase I can't really find any solid info.
Thanks!
Old 06-01-15, 09:57 AM
drbazing
drbazing's Avatar
From my experience, driving all city (stop lights every 1/4 of a mile), I get a difference of 2-3 MPG (15MPG vs 18MPG) between ECO and Sport+ by the time I have to fill up. I drove pretty aggressive when I was on Sport+, while being a grandma on ECO.
Old 06-01-15, 09:59 AM
jkonquer
jkonquer's Avatar
I find that there is virtually no difference in ECO and Normal mode. So i don't even go on the ECO. So from my Normal to occasional SPORT+ I get about 19-21mpg in the city.
Old 06-01-15, 10:03 AM
HanaleiISF
HanaleiISF's Avatar
Not sure if I'm the only one, but I've never put my car into Eco on purpose.
Old 06-01-15, 11:22 AM
JDR76
JDR76's Avatar
Received 1,621 Likes on 1,034 Posts
I don't bother with eco mode. It's very difficult for me to get a valid, direct comparison between normal and sport modes, because I don't drive the same in the two modes. I suspect that if I were to drive in normal mode but drive like I do when I'm in sport, the difference wouldn't be that big.
Old 06-07-15, 04:49 AM
IS350SWFL
IS350SWFL's Avatar
All city driving...21 to 22mpg in normal...18mpg in sport +. Im sure that some of that difference is due to the driving style in each mode (cruising in normal...more aggressive in sport +)
Old 06-19-15, 11:15 AM
Rebirthing
Rebirthing's Avatar
I have a 250 F-Sport.
On Eco, with 70% city / 30% highway, my best was about 23.3MPG.
On Sport, I've gone as low as 16.9MPG (Redlining)
Old 08-28-15, 06:46 AM
Wsalas4
Wsalas4's Avatar
I really dont understand how ppl get 20+ miles.... I drive mostly city, and on normal mode i get 15mpg according to the computer... Normally a full tank around 230miles range before the light comes up... In sport usually around 13mpg... but man i wish i could reach 20 lol, i normally go highway but for 5 to 10 min and the other 20min are city. (I like to speed tho so can't complain and with the 250 you have to push it in order to get a bit of power /= ...)
Old 08-28-15, 04:40 PM
Kov
Kov's Avatar
What is this ECO mode you speak about?
Old 08-28-15, 06:38 PM
mcomer
mcomer's Avatar
All Lexus Hybrids and many gas models now have the Drive Mode Selector with Eco, Normal & Sport. Let us differentiate this Eco as "Active" and the small green Eco light we have seen for years as "Passive" When you
act to twist the **** (or press buttons on CT & HS) the car acts differently. The transmission shifts and throttle response and A/C action all change to use less fuel. Cruise control also is modified because of the soft throttle response. The old tech green "ECO" light didn't change the car, it was trying to change the driver, driving to keep the light on improved the EPA test cycle results. VW created the ruling in the '80's with a "shift now" light for manuals.
Old 09-06-15, 09:59 AM
Aleriance
Aleriance's Avatar
People are forgetting that SPORT mode is for SPORT driving, not for everyday "spirited" driving.
Leaving your car on SPORT mode all the time is a bad idea. You will be causing a lot more wear and stress on your engine than necessary.
Leave your cars on NORMAL mode for crying out loud. Leave SPORT for the track!
Old 09-08-15, 09:03 PM
L0ngJ0hn
L0ngJ0hn's Avatar
If you have the 8spd. Sport+ keeps it in 6th on the highway. That'll chew come gas.
Old 09-09-15, 09:25 PM
chyeea03
chyeea03's Avatar
You can always throw it into M and shift to 8th yourself which gives you the efficiency of 8 gears and the quick throttle response of Sport+ in case you need to drop down and pass someone quickly.
Old 09-09-15, 10:40 PM
Sexis350
Sexis350's Avatar
Its stays on 7th until about 90+mph and wont let you upshift
Old 09-18-15, 01:17 PM
Namster
Namster's Avatar
Not sure how you get this low for an IS250 or even worst than ISF. You should be getting 320-400 miles range. I get 385 miles for my IS250 and 340 miles for IS350 (all mix city 30% / highway 70% ). If all city driving, my 250 can get 320 miles and my 350 can get 285 miles.
Even ISF owners are getting the same or even better range than 250 miles.
https://www.clublexus.com/forums/is-...2012-is-f.html
To get optimum mpg, check your tire pressure, perform full synthetic oil change, clean air filter, put in premium gas, and change driving behavior. Reset the computer and you will see the difference.
Quick Reply: Gas Mileage - Eco Vs. Sport Mode
