Invidia Midpipe + Axleback
#61
I plan to have the Lexus pipe reinstalled, remove the resonator and replace that with a glasspack resonator. And have Magnaflow mufflers installed. All this for $760
Or, should I just go with the Invidia Axelback instead? This part is $650 plus $120 install, unless I do that myself.
My concern is the Invidia Axelback may not have enough deep tone for the cost, where as the glasspack and Magnaflow will.
Thoughts?
Thanks.
#63
I have a megan mid pipe paired with my F sport Exhaust.
What part of NY are you in? Im in Metro NY so if youre close youre welcome to check out the sounds before you make a purchase.
Idk how loud you want but Invidia is def louder than megan, Megan is more of a refined note.
#64
I forgot to ask you Icy350, did you have any issue passing NYS (emissions) inspection with the Megan midpipe? I'm probably going to get the Invidia but I'll get whichever one will not fail emissions or cause a check engine light. Has anyone had issues with either of them as far as check engine lights or emissions failures outside of CA?
I'll be asking $250 with free ground shipping or $225 if you pay shipping.
Not sure how other states will handle the smog check, I'd call your local smog shop and ask them.
Thanks,
Mike
#65
neither midpipe will throw cel since its after the o2 sensors. in california im pretty sure neither will pass emissions, not sure about NY. There's always somewhere willing to pass you tho...
#66
Puhz, I may have an Invidia midpipe (used but like new) that I just installed and will need to remove this weekend since CA will not pass the smog since the two cats are removed.
Thanks,
Mike
Thanks,
Mike
#67
Thanks,
Mike
Thanks,
Mike
