does anyone backfire when you slow down (f-sport exhuast)
Old 06-30-15 | 06:56 PM
Gerb's Avatar
Gerb
Default does anyone backfire when you slow down (f-sport exhuast)
Is this the cylinders misfiring while downshifting? How do I fix running rich. I have reset ecu 2 times.
Old 07-01-15 | 01:56 PM
Gville350's Avatar
Gville350
No, it's not in the combustion chambers...it is unignited raw fuel in the exhaust getting "spent' in the piping. Happens alot when you start adding exhaust-type mods to any vehicle.
Old 07-08-15 | 09:43 AM
hocheung20's Avatar
hocheung20
IS350 here. No backfire problem from the FSport exhaust.
Old 07-09-15 | 03:50 PM
Gerb's Avatar
Gerb
Had it installed for a year now lol. I think its cause my battery got reset when the battery died, so I guess everything got reset.
Old 07-09-15 | 07:13 PM
MWIS350's Avatar
MWIS350
I have same issue and code running rich. I has put in new MAF Sensor and Seaform fuel injector cleaner in gas tank. Car seem to run ok still bogging. But no check engine light. From CL member recommendation I also order 2 new Aire Fuel Ratio Sensor.
Old 07-09-15 | 07:15 PM
MWIS350's Avatar
MWIS350
I had 3 code PO172, PO175 Bank 1 Bank 2 system too rich and bad MAF sensor.
Old 07-10-15 | 07:53 AM
Bichon's Avatar
Bichon
Super Moderator
Have you checked your mid-pipe for exhaust leaks, especially under the heat shield? When it happened to mine, one of the symptoms, besides sporadic P0420 DTCs, was occasional backfires during deceleration.
Old 07-10-15 | 10:45 AM
getafewliv's Avatar
getafewliv
I get the occasional backfire when the car is a bit colder and I accelerate out of the parking lot and then let off the gas. No big deal.
Old 07-12-15 | 07:13 PM
Toxicxk23's Avatar
Toxicxk23
Same! I love it lol If I gas it and let off, the exhaust will gurgle and back fire as the car downshifts. It also does is when I'm slowing down after driving hard. I don't have the F-Sport exhaust though. I got the resonator and mufflers removed.
Old 07-14-15 | 05:10 AM
Gerb's Avatar
Gerb
Nope, haven't check I have no CEL and no VSC lights. I only notice it when its a pretty hard brake. If its slowly decelerate it doesn't backfire but I'm worried running rich might cause some problems.
Old 07-17-15 | 09:48 PM
j3ff's Avatar
j3ff
I always backfired with my f-sport. Like you described and especially right before coming to a stop. I put over 45000kms on it with no issues. Vancouver driven also if it makes you feel better .
Ecko508
09-09-15 04:49 PM
patelmd
11-16-13 11:30 AM
nMeOnE
Performance
18
03-03-10 08:16 PM
bjz3638
RX - 1st Gen (1999-2003)
10-21-07 11:08 PM
zombie
16
04-26-07 08:01 PM
