IS200t tune
#166
$600 ~~if you want let me know~and if you have friend want it more 5 or more I still can give you this price~
#168
Thank you for the offer. I would recommend making a thread to promote the sale of the downpipe, i am sure there are some people on here that would be interested.
#169
Sheddy~I really want you will buy one~this make and text by my friend... Pretty good thing~no place doing this right now...
#170
As promised, today was dyno day with OVTuned.
A few things to note:
1) Our engine is under-rated (supposedly). I'm assuming the dyno compensates for drive-train loss as the graphs say flywheel numbers, but I trust Mathew when he says stuff like that.
2) For whatever reason, you can't get more than 30% throttle until 4000 RPM where it then goes rich to give you power.
There may have a been a few other things that I'm forgetting at the moment.
Sheddy (01-07-17)
#171
#172
Also trying to convince him to make a carbon intake for the 200t crowd as all we have are open cones in the engine bay
#173
Yes they are. The best part is that the reflash can be done through OBD so we wouldn't need to pull out ECUs out. TCU is also in the works, but I'm not certain if that's through OBD; he briefly mentioned it in passing, but I don't fully remember.
#174
Thats great news! Most companies are going the safe route with piggybacks but you definitely get a better result from an actual reflash tune. Keep us posted with their results. Intakes on our cars are highly annoying IMO, perhaps just a larger diameter intake pipe with a drop in filter will give us some extra air for the tune.
#175
I think OVTuned wants to do the full bolt-on package (intake, downpipe, tune). The only question is whether or not they actually will.
#176
Piggybacks vs. reflashes are all about trade-offs. Piggybacks are undetectable, but are limited because works with a few parameters whereas reflash gives you control to AFR tables, fueling tables, and so forth. In the worst case scenario of your engine blowing, I'd rather have a piggyback.
#177
The way the engine bay is set up we can't really get a different intake style. I am sure the injen is a great addition for extra air flow but I just can't stand the excessive engine noise even though to some they might actually think it's cool
#179
I found one I more like..... @#$%&*....
Look better...
#180
